Exhaust Manifold Leak is a definite - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BlowinSmoke, this thread has received 48 replies and been viewed 4875 times.
post #1 of 49 (permalink) Old 04-27-2010, 09:15 PM Thread Starter
BlowinSmoke's Avatar
It did turn out that I'm slowly leaking oil out the exhaust manifold. Anyone ever see or hear of or know about this problem?
BlowinSmoke is offline
post #2 of 49 (permalink) Old 04-28-2010, 01:45 AM
gone fishin!
exhaust valve guide and or seal..... time to do some head work....good time for port and polish.....maby some o rings
ask NukleusX, he had similar problems. just with a p-pump motor
MABB- members against big business
keep the internet free!!!!!!!!
floridaboy is offline
post #3 of 49 (permalink) Old 04-28-2010, 06:47 AM Thread Starter
Is that some pretty labor intensive work?
post #4 of 49 (permalink) Old 04-28-2010, 10:55 AM
gone fishin!
pull the head and strip it down and take it to a shop to press the guides out and press new ones in...... i wana say it was like $150-$180 last time i had one done plus
the parts are cheap.
post #5 of 49 (permalink) Old 04-28-2010, 04:42 PM Thread Starter
Dont you have to pull quite a bit off as well, not just as simple as it sounds although it may as well be simple. I'll take a look at my diesel supplement see how it goes.
post #6 of 49 (permalink) Old 04-28-2010, 05:09 PM
BigRed Cummins's Avatar
I just paid around $350 to surface the head, do a valve job, and cut it for fire rings. I will be pulling my head soon and can document the whole thing if you would like. It definitely sounds like you have bad valve seals, or worn valve guides.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #7 of 49 (permalink) Old 04-28-2010, 05:18 PM
SSpeeDEMONSS's Avatar
dont ask Nuk, he never addressed that problem.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #8 of 49 (permalink) Old 04-28-2010, 08:08 PM
gone fishin!
ha never mind.
pulling the head and stripping it down is easy, then you take all your rockers and springs off, drop the valves out and clean it all up....then take it to the machine shop and they do the rest of the work... then just put it back together and slap it back on....
post #9 of 49 (permalink) Old 04-28-2010, 10:08 PM
To get oil to flow out the exhaust guides they would really have to be bad and when you remove the valve cover there would be a lot of carbon. The exhaust side is under preasure 99.9% of the time. Before I pull the head I would do a cylinder leak down test, to see if you have a bad cylinder. If you pull the head and there is a ring about 1/2 inch, clean, and wet on the piston top it is a broken ring or bad cylinder problem. Just a thought!
Johnp3 is offline
post #10 of 49 (permalink) Old 04-29-2010, 10:09 PM Thread Starter
Thanks guys. Yeah I'd love to read your write up, my rear axle seals just started doing that so I can do that in the mean time. The manifolds been leaking for a few months now.
These valve seals or guides do they just press in?
Dumb question but is the machining critical. I mean after measuring everything. I have a diesel supplement so that helps as well as talking to you guys.
Also anyone have a cylinder head weight?
Exhaust Manifold Oil Leak BlowinSmoke 5.9L Cummins (Pre 1994) 20 07-08-2010 12:16 AM
6.7L exhaust manifold your nightmare Supporting Vendors Forum 3 03-24-2010 06:36 AM
12v ATS exhaust manifold bmoeller Whats Been Sold 2 06-06-2009 09:40 PM
Exhaust manifold cowboytw13 5.9L Cummins (1998.5-2002) 12 02-06-2009 05:49 PM
leak below exhaust manifold dcbdanboy 2003-2007 6.0L Power Stroke 4 10-09-2007 06:42 PM
