Auto to manual swap - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 9 replies and been viewed 10620 times.
post #1 of 10 (permalink) Old 05-25-2010, 02:41 AM Thread Starter
cumminsdiesel's Avatar
Auto to manual swap
Have a chance to pick up a 91 4x4 with 150,000 miles for $2,000. But it has an auto and I want to swap it out for a manual. What can I expect to pay for a used getrag trans and what problems would I run into other than drivelines, crossmember, and clutch pedal. Thanks
cumminsdiesel is offline
post #2 of 10 (permalink) Old 05-25-2010, 04:35 PM
The getrag with a Tcase would run you around 1k. If the truck has a 727 in it. You wouldn't need driveshafts. If the truck has a 518 trans. Drive shaft work would be needed. The front would need to be shorted. The rear would need lengthened.
Clutch/ brake pedals are just a bolt in. No big deal there.
Clutch Hyd's. If you use 1st gen hyd's. Its a straight bolt in also. If you go to later hyd's. Just let me know. I can tell you what is different between them.
I just did a auto to G56 6spd swap last month.
Philip is offline
The Following User Says Thank You to Philip For this addition to TDG:
cumminsdiesel (05-26-2010)
post #3 of 10 (permalink) Old 05-26-2010, 01:38 AM Thread Starter
Is the transfer case diffrent in the auto trucks than the manual trucks then?
post #4 of 10 (permalink) Old 05-26-2010, 04:53 AM
BigRed Cummins's Avatar
Transfer cases should be the same. It will probably cost you more than you paid for the truck to swap it to a manual. If you haven't bought it yet, I would hang on and wait for a manual to come along. It took me almost a year to find mine.
1992 W250-P-pump and some extra air, gone, but not forgotten.
2003 SVT Cobra
1984 Chevy K10
BigRed Cummins is offline
post #5 of 10 (permalink) Old 05-26-2010, 10:24 AM
strawboss's Avatar
If you try this keep us updated, I thought about swapping my 5r110 for a 6spd.
www.libertyantiquetractorpull.com
"Never before have so few, fed so many, for so little"
strawboss is offline
post #6 of 10 (permalink) Old 05-26-2010, 12:37 PM
The Tcases have different input shafts.
All Dodge CTD auto Tcases use a 23 spline input shaft. It doesn't matter on the year model.
A Dodge CTD stick shift Tcase uses a larger 29 spline input shaft.
Thats why I mentioned getrag with Tcase as a package.
Philip is offline
post #7 of 10 (permalink) Old 05-27-2010, 01:49 AM Thread Starter
where would a good place to look for trans and transfer case be?
post #8 of 10 (permalink) Old 05-28-2010, 01:04 PM
Just have to watch the classified adds around the diesel sites. Sooner or later they do show up.
If you want to use a later model trans. That isn't a problem. You can use all the way up to a G56. The big item is that 29 spline Tcase. Once you get you hands on that. Any other Dodge CTD trans can be made to fit pretty easy.
Philip is offline
post #9 of 10 (permalink) Old 06-03-2010, 01:01 PM Thread Starter
ok thanks. I also found another 91 4x4 with 148000 manual for 3000 that I got to go look at friday.
post #10 of 10 (permalink) Old 11-19-2010, 01:17 AM
would you think about selling the auto trans??
67c10 is offline
auto to manual swap danhousjr Whats Been Sold 0 03-30-2009 10:06 AM
Manual to auto swap? 9 Lives Diesel Conversion 1 11-16-2007 11:06 PM
auto to manual swap? imported_7inchstack 5.9L Cummins 12 Valve (1994-1998.5) 1 05-23-2007 04:58 AM
Auto to Manual Swap in 04.5 patriot2500 5.9L Cummins (2003-2007.5) 4 12-13-2006 09:26 PM
97`psd auto to manual swap BogginF350 1994-2003 7.3L Power Stroke 4 01-31-2006 12:14 PM
