oil supply on h1c - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 91/2 7.3idi, this thread has received 3 replies and been viewed 1227 times.
post #1 of 4 (permalink) Old 05-27-2010, 01:12 PM Thread Starter
91/2 7.3idi's Avatar
Send a message via AIM to 91/2 7.3idi
oil supply on h1c
does any body know what size fitting i need to connect the oil supply to an h1c. is it a special fitting or pipe thread and what size? thanks
Nick
91 f-250 xcab,long bed,7.3 idi(soon to be a dt 360) 5 speed, 33's, pump turned up, ultra-lite gauges and 6 inch flat black miter cut stacks. coming soon:turbo and intercooler.
97 gmc 2500 2x4 6.5 turbo 5 speed. k&n intake and muffler cut off. gone but not forgotten
01 gmc 2500hd duramax xcab long bed 4x4. straight piped
91/2 7.3idi is offline
post #2 of 4 (permalink) Old 06-06-2010, 10:09 PM
bmoeller's Avatar
It is a special adapter from the line to the turbo. The line end is a compression type fitting (similar to what would be on a brake line), and the other side that screws into the turbo is o-ring.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 4 (permalink) Old 06-06-2010, 11:57 PM Thread Starter
thanks. so i have what is supposed to be the factory feed line and i just need the adapter
Nick
post #4 of 4 (permalink) Old 06-10-2010, 12:21 AM
bmoeller's Avatar
Yep. IIRC, ~$5 at Cummins. Need one for both ends, if you don't have either one.
bmoeller is offline
91/2 7.3idi (06-12-2010)
CAT Update VVA Oil Supply Line hispeed428 Medium and Heavy Duty 2 08-27-2009 05:44 PM
IH to supply Capacity Binderpower Medium and Heavy Duty 3 06-02-2009 06:29 AM
Fuel supply pump Smokin Joe 2008-2010 6.4L Engine Tuner Forum 9 05-25-2009 04:58 PM
Best place to tap an oil supply LargeCar 2003-2007 6.0L Power Stroke 5 04-17-2007 04:23 AM
VGT Oil supply tube PSDPlayer 2003-2007 6.0L Power Stroke 20 02-08-2006 01:52 AM
