Oil Pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cumminsdiesel, this thread has received 11 replies and been viewed 2409 times.
post #1 of 12 (permalink) Old 06-05-2010, 01:56 AM Thread Starter
cumminsdiesel's Avatar
Oil Pressure
Truck is a 91 with 174,000. When driving oil pressure is fine but when you stop it drops down and light comes on. As soon as you give it a little gas it jumps right up fast. Owner says its done this since it was almost new. Any ideas what would cause this?
cumminsdiesel is offline
post #2 of 12 (permalink) Old 06-05-2010, 04:55 AM
Stuck pressure relief valve in the oil cooler.
Defective oil pump
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 12 (permalink) Old 06-05-2010, 04:35 PM Thread Starter
Is there a way to do a process of elimanation between the two. Im guessing the relief valve would be much easier to fix. Also how hard would the oil pump be to change? Thanks
post #4 of 12 (permalink) Old 06-06-2010, 06:15 AM
I have not cleaned the bypass but recall a diagram showing it under the large hex on the oil cooler behind the filter.
The oil pump is behind the front cover that needs to come off to fix the KDP.
First thing would be to check the oil pressure with a mechanical gauge - the plug next to the turbo oil line. The action of the gauge would point - picking up rapidly with rpm and going high would be a stuck regulator, just getting off the light would point to a poor pump or other internal leak. There may be a burr that stops the regulator stroke so the pressure rises to normal and regulates.
keydl is offline
cumminsdiesel (06-08-2010)
post #5 of 12 (permalink) Old 06-06-2010, 10:11 PM
bmoeller's Avatar
Checking against another gauge would be the best place to start. Could be a bad sending unit.
"Obama = Hoax and Chains"
bmoeller is offline
post #6 of 12 (permalink) Old 07-07-2010, 02:43 AM Thread Starter
Finally got another mechanical gauge to check pressure. Started truck and at idle pressure was 48psi. Let truck warm up and drove around for about 25 min. Wide open pressure read 68 psi and at idle was 22 psi. Whacha yall think?
post #7 of 12 (permalink) Old 07-07-2010, 03:56 AM
First is an oil and filter change, make sure the oil is diesel rated.
Second is to pull the pressure regulator in the oil cooler.
The broken number is 15 psi but most will hold 40 at idle and 25 is where I start plans for a cure on my stuff.
If the KDP has not been cured and the pressure regulator is clean and free in the bore I would pull the oil pump and check the clearances.
The other thing on the troubleshooting tree is an air leak on the pickup tube, long term thing so that is far down the list.
The oil and filter change cover a fairly long list of possible problems so a gauge reading after is nice, the pressure bypass relief valve is simple - measure that the piston moves freely full length in the bore. I would guess that that is the highest probability as most regulate at 65 PSI.
keydl is offline
post #8 of 12 (permalink) Old 07-07-2010, 04:29 AM Thread Starter
gong to change oil this weekend. The truck wont be driven so it will be ok till then.Are the oil pressure regulator and the relief valve part of the same unit
post #9 of 12 (permalink) Old 07-07-2010, 08:19 PM
My error in english - they are the same. Purpose is to control the oil pressure which would change from temperature and volume. A tight engine may make 300# with a stuck valve and a worn out one may still run with 4#.
keydl is offline
post #10 of 12 (permalink) Old 07-08-2010, 12:44 AM Thread Starter
Were in the crap is the valve. I looked all over heck and cant find it.
How do I change the pressure of the tire pressure sensors? Klutch 2008-2010 6.4L Engine Tuner Forum 3 11-23-2009 02:09 AM
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 06:33 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
anyone doing fuel pressure or oil pressure skinz0021 General Dodge Discussion 7 08-19-2006 02:42 PM
