Heater stuck on max heat. :( - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bmoeller, this thread has received 7 replies and been viewed 1425 times.
post #1 of 8 (permalink) Old 06-06-2010, 10:27 PM Thread Starter
bmoeller's Avatar
Need a bit of help guys. Did a search and came up dry.
Got a '92 in Feb, and the heater is still stuck on. This is my first 1st gen, so I'm in new territory.
Don't know how the controls work for sure. Fan works, and the "off" button turns the fan off, but that seems to be it. Blend door moves freely, and no functioning A/C (yes it is charged, so good there).
There is a vac operated valve of some sort on the one heater hose. No vac on that line, and no change in temp with a hand operated vac pump is hooked up (and no leak down on the pump gauge). Either the valve is stuck open or,..........
Any ideas?
TIA.
"Obama = Hoax and Chains"
bmoeller is offline
post #2 of 8 (permalink) Old 06-07-2010, 03:12 AM
Best solution for the heater is shutoff valves - the same as a big truck, the vacuum valves often leak.
If it did not shift with vacuum - it is stuck. Turn the gauge to the control line and see if there is vacuum in the heat position of the controls, there is a plug for the vacuum supply line on the firewall above the heater blower that seems easy to unplug.
If the heater valve line switches vacuum with the control, then run a jump wire to the clutch wire on the compressor. Check for magnetic with a wrench or something, if it is tap the armature to see if the air gap is to much. If the compressor turns, then check the charge.
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 8 (permalink) Old 06-10-2010, 12:20 AM Thread Starter
bmoeller's Avatar
Thanks for the help.
I already figured on getting shut off valves. Bought the fittings at the KW dealer today. Just need to pick up the valves.
Given this truck was a builder, I'm not sure what all is right or not yet. Still have a few other things to figure out.
bmoeller is offline
post #4 of 8 (permalink) Old 06-13-2010, 09:18 PM Thread Starter
bmoeller's Avatar
bmoeller is offline
post #5 of 8 (permalink) Old 07-07-2010, 09:51 PM
RJC
Same Problem
I have the same problem with my 1993, Heater is stuck on hot also notice when i first run the truck I can see little steam coming out of the vents and windsheild fogs a little. After a while it would clear up no more steam but still blowing hot air. The previous owner had the heater core replaced about 1 1/2 year ago. Shouls i go with the valve set up like Bmoeller or is there another fix?
Thanks
RJC is offline
post #6 of 8 (permalink) Old 07-08-2010, 12:28 AM
The pair of valves are used on HD trucks so that the heater core and hoses can be shut off in case of a leak and one can be turned off to stop heatin the core in warm weather.
If the steam is not from A/C condensate then there is a leak in the heater core.
That it is not spilling coolant means the leak is small - it might be cured with stop leak.
Most of the factory heater valves leak a little so adding a valve to stop coolant flow is a plan, A second valve is really not wasted - old trucks seem to use more parts than new ones. That way there is no wasted time when a heater hose or core leaks, just turn the valves.
keydl is offline
post #7 of 8 (permalink) Old 07-08-2010, 05:10 AM
RJC
So is this valve available any hardware stores or is there a dealer that carries them. Looking at picture. looke like it it installed between heater hoses?
I will try stop leak but still will like to add valves?
Do you know if heater control is operated via cable?
Thanks
RJC is offline
post #8 of 8 (permalink) Old 07-09-2010, 06:28 AM
Valves are 1/4 turn ball valves in 3/8's or 1/2 inch with 5/8 hosebarb adapters, I think that the ones on a Detroit are 1/4 turn 1/2 male pipe to 5/8's inverted flare.
The stock heater valve is vacuum actuated. There are cable operated valves so the amount of flow can be set but you would need a cable to work it.
Make sure the system is clean if you use stopleak.
keydl is offline
block heater and magnetic oil pan heater DZL BULL 2003-2007 6.0L Power Stroke 3 12-14-2009 01:20 PM
sometimes heat sometimes no heat WTF Superstroker 2003-2007 6.0L Power Stroke 24 02-10-2009 02:17 PM
how to check for heat stuck on defrost or 4x4 auto lock inop imported_cb44473 2003-2007 6.0L Power Stroke 3 04-17-2008 05:35 AM
Heater stuck on defrost? danktank6.9 1994-2003 7.3L Power Stroke 9 01-23-2008 04:12 PM
Little heat Birchwooddiesel 7.3L and 6.9 IDI (Pre 1994) 6 04-12-2007 02:47 PM
