Shifting issue - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ewales, this thread has received 6 replies and been viewed 957 times.
post #1 of 7 (permalink) Old 06-12-2010, 02:30 AM Thread Starter
Shifting issue
I have an 01 Dodge 338,000 KM that justed started having an issue with the 1-2 shift. Once it makes the shift it goes through the rest of the gears and into lock-up with no problems. Fluid is at the correct level, it is also Amsoil Synthetic, has been for about 300,000 km's and the fluid looks and smells good. This issue just started in the last 2 or 3 days, 1st couple of days very intermittent, today full time.
ewales is offline
post #2 of 7 (permalink) Old 06-12-2010, 03:21 PM
MY 2002 HAD A SOLENIOD IN THE TRANNY GO OUT.
hin0031 is offline
post #3 of 7 (permalink) Old 06-13-2010, 01:51 AM
before spending the money, here is a free tip. With the truck off get under the truck and on the drivers side there is a speed sensor towards the back of the transsmision before the transfercase meets the tranny. unplug it and you will need a big wrench to unscrew it. take it out and if there is a little fuzz on it wipe it off clean and put it back in. This is normal wear and tear overtime driving. If that don't fix the problem then have the pan dropped and replace both the solenoids wile the pan is off.
cumminsdude2001 is offline
post #4 of 7 (permalink) Old 06-13-2010, 03:26 PM
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #5 of 7 (permalink) Old 06-16-2010, 01:09 AM
bmoeller's Avatar
Had to replace the gov pressure solenoid and gov pressure sensor on my stock '97 auto to solve the 1-2 shift issue. Parts were ~$100 each.
"Obama = Hoax and Chains"
bmoeller is offline
post #6 of 7 (permalink) Old 06-16-2010, 03:50 PM
Is the trans stock or built? If you can get it on a good diagnostic tool that will help to see what is going on. Since the 1-2 shift is still a hydrualic shift with hydrualic pressure being controlled by the gov. solenoid, that is probably where your problem lies. The nice thing about putting it on a good tool, is you can checking the readings from all of the different sensors and see which ones aren't reading how they should. And also see if actual gov. press. matches desired gov. press.
post #7 of 7 (permalink) Old 06-18-2010, 04:57 PM
IDImonsterstack's Avatar
my truck had the same problem 6 times it was the 2nd gear adjustment band. its just a little like cast iron cup with a bolt that pushes on it and they brake off causing it to slip. it gives you the impression that 2nd gear is blown up but its just not grabbing. beware driving it like that you WILL destroy your trans in a matter on mins i did and the trans cost me a little over 4500 to have it built they are not cheap.
under the knife for rebuild
IDImonsterstack is offline
SCT shifting Bigking 2003-2007 6.0 Tuner Forum 14 11-13-2009 04:47 PM
SCT shifting drservo 2008-2010 6.4L Engine Tuner Forum 9 01-10-2009 11:27 PM
Not shifting into O/D. sstockton 5.9L Cummins (1998.5-2002) 4 11-09-2007 11:19 PM
SCT Shifting Help Please wellstroked 2003-2007 6.0 Tuner Forum 14 05-16-2006 09:00 PM
tune issue or tranny issue? licketysplit 2003-2007 6.0L Power Stroke 10 02-14-2006 10:58 AM
