5 or 6 speed - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 6.0brianDRW, this thread has received 21 replies and been viewed 2785 times.
post #1 of 22 (permalink) Old 06-15-2010, 12:15 AM Thread Starter
6.0brianDRW's Avatar
5 or 6 speed
im looking at a few trucks with the 24v motor. some have the 5 and some have the 6. is there a specific year that they switched or is it an option. i would think the 6 is better but im not sure.
2003 jeep wrangler rubicon 4.0/NV3550
'06 f-350 DRW king ranch.(gone but not forgotten)
458rwhp/764rwtq
[email protected]
1989 F-150 300 I6/M5ODR2/6 in a row makes it go
1982 mustang. 351W/414 stroker C4 9" rear. bracket racer
1977 F-100 getting a 1996 12v cummins engine (project)
6.0brianDRW is offline
post #2 of 22 (permalink) Old 06-15-2010, 12:37 AM
bmoeller's Avatar
The 6spd was mainly behind the 245hp HO engine. The exception would be a few early '99 trucks and the input shaft was also smaller on those.
If you want to mod the engine any, the 5spd trucks give the best results from fueling boxes.
Problem with all of the NVG drivetrain parts, is that the business has closed up shop. Hard to find most parts for a complete rebuilt.
Have the 5spd myself, and it has performed well for me. I do like the ratios on my Getrag in the '92 better, though.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 22 (permalink) Old 06-15-2010, 01:09 AM Thread Starter
so if im reading this right the 6 spd probably has a stronger engine but the 5 spd will do better with a modified engine? which trans is stronger?
458rwhp/764rwtq
[email protected]
post #4 of 22 (permalink) Old 06-15-2010, 01:44 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
stronger thats a tough one imo i would have to lean towards the nv4500 if i get a older truck it will have the 5sp
Military Quote Of The Year
SOOTBANDIT is offline
post #5 of 22 (permalink) Old 06-15-2010, 01:52 AM Thread Starter
hmm good to know.
i found a truck that i like except it has no cd player or cab lights. i can do the cd player easy enough but i like having the cab lights. are thery easy to do or should i just find one with cab lights?
458rwhp/764rwtq
[email protected]
post #6 of 22 (permalink) Old 06-15-2010, 01:57 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
buddy did his on a 09 in like a few hours hardest part is getting the nerve to cut a hole in your roof
post #7 of 22 (permalink) Old 06-15-2010, 02:05 AM Thread Starter
im always nervous cutting anything on a car. you shouldve seen me when we were doing the stacks on my 06. i couldnt even do it. someone had to do it for me.
458rwhp/764rwtq
[email protected]
post #8 of 22 (permalink) Old 06-15-2010, 02:19 AM
Built Not Bought
SOOTBANDIT's Avatar
Images: 9
i know the feeling he was scared thought he was going to cry but he did it no problem and looks factory you wouldnt know unless he told you
post #9 of 22 (permalink) Old 06-15-2010, 04:25 PM
Singles Club #2
smokndiesel7588's Avatar
x2 on the easy installation...we did my brothers and my buddies in the same day.
Greg
smokndiesel7588 is offline
post #10 of 22 (permalink) Old 06-15-2010, 11:11 PM
Ghost
Phily's Avatar
correction
6spd is a good clutch and stock engine will last longer than the engine.
The 6spd was mainly behind the 245hp HO engine. The exception would be a few early 2000 & 1999 trucks and the input shaft was also smaller on those.
Phily is offline
7 speed spicer to a 9 SPEED EATON/FULLER bayou hotshot Medium and Heavy Duty 6 01-21-2010 10:06 PM
Allison five speed vs six speed identification? stealth71 GM Transmissions 13 10-24-2009 08:51 PM
switching from a manual 5 speed to a manual 6 speed BEHR2010 1994-2003 7.3L Power Stroke 13 04-25-2009 03:27 PM
Allison 1000 5-Speed to 6-Speed Conversion stevebos GM Transmissions 8 01-09-2007 06:21 AM
High speed sometimes low speed vibration masonjo 5.9L Cummins (1998.5-2002) 2 11-08-2006 02:27 PM
