need help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by big c777, this thread has received 4 replies and been viewed 642 times.
post #1 of 5 (permalink) Old 06-15-2010, 02:35 AM Thread Starter
Angry need help
i have an o1 2500 cummins auto when im driven my truck just falls on it face and if i let out of it it starts driven fine but it does this over and over for a few min then it will be ok and the it will star acting up agin i just replaced the tps sencer any help with this problem would be great thanks
big c777 is offline
post #2 of 5 (permalink) Old 06-15-2010, 02:47 AM
Did you scan for any codes? I would start there. How bout your fuel filter? when was that last changed? Could also be a sign that the lift pump is failing or has already. If it is then you will be doing a VP44 in the near term. Check for codes first.
cumminsdude2001 is offline
post #3 of 5 (permalink) Old 06-15-2010, 04:27 PM
Singles Club #2
smokndiesel7588's Avatar
sounds like the trucks hopping in and out of limp mode...been there a million times Start by checking for any codes. If you post the codes up here, we'll help ya get a diagnosis.
Greg
smokndiesel7588 is offline
post #4 of 5 (permalink) Old 06-16-2010, 10:07 PM Thread Starter
the codes are p0122 po460 p1693 i can clear them but they cum right back
big c777 is offline
post #5 of 5 (permalink) Old 06-17-2010, 07:14 AM
That dead pedal that you are describing generally goes hand in hand with 1 of 2 things. Either a failing VP44 or a failing APPS. The code that you are throwing P0122 is APPS input below the acceptable minimum voltage. P1693 is a companion code, all it means is that an error has been detected in either the PCM or ECM. What APPS are you running? That is the direction I would be looking towards right now.
