Lifting options - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lbdodge24v, this thread has received 4 replies and been viewed 986 times.
post #1 of 5 (permalink) Old 06-16-2010, 06:22 PM Thread Starter
lbdodge24v's Avatar
Lifting options
I am thinking about taking the 2 in leveling kit off my truck and replace it with a set of 3.5 in progressive rate coil springs. My question is, would I be better off to get the springs from one place, the link arms from another, a track bar replacement or fix, and what ever is needed for the rear from somewhere else? Looking at the price difference from getting a complete kit and piecing together one of my own from different places.
Who has the best link arms for our trucks?
What is the best track bar relocation or fix for our trucks?
What are your thoughts on this? Which route would you take?
Thanks in advance for any and all help!
02 Dodge Ram CTD, 6 spd., HMR Street Drag Clutch, Raptor 150, Edge Drag Comp, Smarty, Injectors, aFe air intake, 2 in leveling kit, 4 in exhaust, and 3 guages-Fuel Pressure, Boost, and EGT's.
The Toy a Jummins!!
lbdodge24v is offline
post #2 of 5 (permalink) Old 06-16-2010, 11:56 PM
If you are looking for a kit that doesn't just change ride height but also improves suspension performance, I would talk to either Don Thuren, or Sage at Carli suspension.
Thuren: http://www.thurenfabrication.com/home.html
805-886-9250
Carli: http://www.thecarlisuspension.com/
714-532-2798
The Following 2 Users Say Thank You to sstockton For this addition to TDG:
lbdodge24v (06-17-2010), Phily (06-17-2010)
post #3 of 5 (permalink) Old 06-17-2010, 04:02 PM Thread Starter
lbdodge24v's Avatar
Thuren and Carli both have some good stuff, but I am afraid a lil out of the price range I am looking to spend. I was looking at the Top Guns Customz stuff, but am not set on anything, except how much I am willing to pay.
I also know the saying "You get what you pay for" can apply also.
The Toy a Jummins!!
post #4 of 5 (permalink) Old 06-26-2010, 04:07 AM
2nd Gen Guru
Mopar1973Man's Avatar
Just another thought to consider...
Just be aware of how much lift you put on a vehicle because the taller you stand in the wind the lower your fuel mileage will be come...(Wind Drag / Frontal surface / Rolling resistane / Rotational Mass)
So in the long run your going to pay daily at the pump just to look cool...
Typical stock 2nd Gen is 0.46 to 0.48 drag coeffient... (graph is rough calculations)
But with lift kits it can go up quickly...
Just something to think about...
Mopar1973Man is offline
post #5 of 5 (permalink) Old 06-30-2010, 01:50 AM Thread Starter
lbdodge24v's Avatar
ahh, only be another inch over what it is now. I just mostly want to swap out the leveling kit for a set of coil springs that might ride better. But that is some good info about the fuel milage. Planning to run the same size tires and everything. thanks for the good info mopar.
The Toy a Jummins!!
Lifting a 2wd ? firedoger General Dodge Discussion 1 01-16-2009 01:59 AM
lifting a DRW over29 General Diesel 4 09-26-2007 09:21 PM
Lifting on 08 F-450? Big Bad Stroker 2008-2010 6.4L Power Stroke 10 06-04-2007 01:41 AM
lifting cab off strokin6L 2003-2007 6.0L Power Stroke 20 05-29-2007 05:44 PM
lifting 06 psd ????? Rww General Ford Truck and Excursion 6 05-15-2006 06:03 PM
