A/C question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 16 replies and been viewed 1520 times.
post #1 of 17 (permalink) Old 06-18-2010, 05:04 PM Thread Starter
IDImonsterstack's Avatar
A/C question
on my 01 i have never had good AC in it becasue the vents are stuck on the floor vents for all positions on max AC and reg. AC it still blows out on the floor and defrost but almost nothing comes out the dash vents. ive posted this before a long time ago on other sites and got no awnsers.
under the knife for rebuild
IDImonsterstack is offline
post #2 of 17 (permalink) Old 06-19-2010, 06:29 AM
When vacuum is lost it defaults to defrost position in the air box, if the vacuum is present at the heater control the next check is vacuum motors that control the dampener doors in the air box that redirect the air. Do they move and hold vacuum. If they leak the airflow may not move the motor. A vacuum line may be disconnected from the control or the motors. It may have swallowed pencils and junk from the deforst vents.
81 Isuzu /C223na, 5spd
keydl is offline
post #3 of 17 (permalink) Old 06-19-2010, 11:49 PM Thread Starter
where are the vaccum motors at. ive looked under the dash there is so much stuff there!
post #4 of 17 (permalink) Old 06-20-2010, 03:52 AM
I had a problem a few times with my vacum diaphram/motor under the center of the dash close to the floor. The rod the connects to the diaphram kept getting disconnected. It did it all on its own. It has been a while since it happened last but I got nothing but air from the floor when that happened.
cumminsdude2001 is offline
post #5 of 17 (permalink) Old 06-20-2010, 05:28 AM
There is a clip for the rod that holds it on.
Vacuum motors have a rod that strokes with change in vacuum on the tube(s) connected.
keydl is offline
post #6 of 17 (permalink) Old 06-20-2010, 09:37 AM Thread Starter
ok that might be the problem i am having casue no matter what posistion the dial is on it always blows on the floor. do i have to take any of the dash to fix it or is it semi easy??
post #7 of 17 (permalink) Old 06-21-2010, 11:07 AM
Singles Club #2
smokndiesel7588's Avatar
Another thing to check is all the vacuum lines under the hood. When I had my 6spd put in, the shop didnt reconnect the vacuum line that goes to the transfer case and I couldn't get air out of anything but the defrost vents. So check to see if your 4wd still works. That could help determine if its a vacuum line or if that rod is disconnecting itself.
Greg
smokndiesel7588 is offline
post #8 of 17 (permalink) Old 06-21-2010, 01:37 PM
2nd Gen Guru
Mopar1973Man's Avatar
Here you go...
Bottom of the HVAC unit on the driver side...
Mopar1973Man is offline
post #9 of 17 (permalink) Old 06-21-2010, 11:31 PM
check this 2 line, the 1/4in line run to the L shape hose below the VP for crack, broke. Check that to make sure you have a good vacuum as it happen to my AC and after replace the soft L rubber then everything was back to normal. Something to look in to as you can see how bad this rubber hose was
1999 Dodge 24V CTD 4x4 dually, nv4500, 152000 miles,dual pillar gauge with boost/EGT in one and with front and rear trans in one gauge oper. by the in pillar switch. BD torque converter and triple disk,TC Lock-Up Switch,MagHytec Transmission Pan, Edge Com, Air-Raid intake system, 5" exhaust system, FASS 95,BD valve body,2" dually spacer with 265/75/16
99CTD is offline
post #10 of 17 (permalink) Old 06-22-2010, 05:47 AM Thread Starter
4wd has worked all the time i use it every weekend at the truck pulls. so ill check under the hood. as for the arm under the dash do i need to remove any p;astics to get to it or make it easier?
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 03:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 12:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 12:40 PM
