Edge Comp Bugs? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JMeier, this thread has received 10 replies and been viewed 3127 times.
post #1 of 11 (permalink) Old 06-25-2010, 01:03 PM Thread Starter
Edge Comp Bugs?
About three months after I installed an edge comp I was driving to work and the petal went dead. This lasted about 5 seconds and then the truck sputtered the CEL came on and the truck went to running fine. Over a period of three months this would happen periodically, and each time the CEL light would go off on its own after two or three cycles. The other night I was driving home and the lift pump quit running. My fuel pressure dropped to zero and I limped the truck home (less than 1/8 mile). The next morning I unplugged the comp and everything has been running fine since. I bought the comp box used so I dont know anything about it. Has anyone else had this happen?
2001 3500 Dually Flatbed, 24v 5 speed, 3.55 gears.
JMeier is offline
post #2 of 11 (permalink) Old 06-25-2010, 01:26 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
sounds like an bad apps or more likely with the lift pump gone an injection pump. Could also be the Edge like you said but I would lean towards the vp44 goin,good luck
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
The Following User Says Thank You to MILKINGCOWBOY For this addition to TDG:
JMeier (06-25-2010)
post #3 of 11 (permalink) Old 06-25-2010, 03:48 PM
if you have the factory lift pump they will do that work and not work etc. I would get a better lift pump before your left buying a better lift pump and a vp44. the apps can do crazy things when they start going out. Mine went out I would be driving along in cruise and the truck would slow down speed up slow down really quick it was a fun drive home.
01quadcab is offline
The Following User Says Thank You to 01quadcab For this addition to TDG:
JMeier (06-25-2010)
post #4 of 11 (permalink) Old 06-25-2010, 07:17 PM Thread Starter
Spoke too soon!!!!!
FML!! I spoke too soon. I was driving home from work and the same thing happened again. The truck stalled at idle for 5 seconds and then came back to life and the CEL came on. This time it did it twice in less than 10 minutes. My fuel pressure never dropped. I whipped into autozone and had the codes read and P0121 came up. They only wanted $411 for the throttle position sensor. Any recommendations on where to buy one cheaper? Is this a complicated procedure? Thanks for the help so far!
JMeier is offline
post #5 of 11 (permalink) Old 06-25-2010, 07:24 PM
JLWelding's Avatar
Get your apps from Timbo approx. 165.00
JLWelding is offline
The Following User Says Thank You to JLWelding For this addition to TDG:
JMeier (06-25-2010)
post #6 of 11 (permalink) Old 06-25-2010, 08:21 PM Thread Starter
Thanks! Got one on its way!! And thanks to mopar1973man and his insight on his site!
JMeier is offline
post #7 of 11 (permalink) Old 06-26-2010, 03:38 AM
2nd Gen Guru
Mopar1973Man's Avatar
Thanks...
But there is only 2 things that cause dead pedal...
1. Bad/failing APPS
2. Bad/failing VP44
But the answer is just as close a OBD II scanner away... Just check the error codes and the code will tell you the story...
Mopar1973Man is offline
post #8 of 11 (permalink) Old 06-28-2010, 11:15 AM
Originally Posted by Mopar1973Man View Post
Thanks...
1. Bad/failing APPS
2. Bad/failing VP44
You have forgotten more than I will ever know about this truck but; I recently got back from another four thousand mile trip and my third Edge problem. The truck coasted to a stop still running but would not respond to the throttle. After disconnecting the Edge and the negative battery cables I got it back on the road. This is like I said problem number three and also my second Edge because they replaced it once at no cost to me. The thing that all three issues had in common is many hours of driving in hot conditions with the A/C on and not ever shutting it down on stops. So the plan is to send it in again and then relocate the control box where it cant get heat soaked . I like my Edge but if it happens again after that I am done!
road runner is offline
post #9 of 11 (permalink) Old 07-02-2010, 12:17 AM
this is where the comp box is better it's inside the truck not under the hood. I like my comp way more than I did my juice. hopefully by next weekend my truck should be 7xx doing a few more mods but keeping the factory so pump
road runner (07-03-2010)
post #10 of 11 (permalink) Old 07-03-2010, 11:11 AM
Ya in the cab is what I was thinking this time around. If that won't solve the problem a different system is not out of the question. I know that if I give up on the Edge;I will miss the 2-4 mpg and the throttle response- that just seems nicer to drive than stock.
edge comp or edge juice w/attidue fitz1985 5.9L Cummins (1998.5-2002) 13 10-03-2007 01:43 AM
Edge comp STROKER SMOKER 5.9L Cummins (1998.5-2002) 4 07-03-2007 08:19 PM
Edge Drag Comp vs. Edge Juice/Attitude lbdodge24v 5.9L Cummins (1998.5-2002) 12 03-08-2007 08:31 PM
edge juice and edge comp??? masonjo 24 Valve Performance 19 01-23-2007 11:51 PM
stacked my edge comp with my drag comp today, it hauls butt OFFRODEN 5.9L Cummins (1998.5-2002) 22 11-30-2006 06:43 PM
