south bend throw out bearings? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MILKINGCOWBOY, this thread has received 4 replies and been viewed 4477 times.
post #1 of 5 (permalink) Old 07-05-2010, 02:37 PM Thread Starter
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
Any one have any issues with them? I put a South bend clutch kit in around 14,000 miles ago right before we replaced the tranny. I love the clutch and have had no issues till yesterday. It started making a whining high pitch metal to metal sound. going down the road. I put the clutch in and it got much worse. Let it out and it was fine then would come back once in a while, if I taped the clutch pedal it would go away. Every time I push the clutch in it makes the noise. Be leave it or not it seems to shift ok when I have to use the clutch. I rarely use the clutch to shift so getting home with out using it was normal besides to start and stop. When I got home there was smoke from the bell housing and I looked up and there is a little gap in between the bell housing and i saw a few little balls right there at the bottom of the cover rolling around. So I would say the throw out bearing blew apart? Any one with similar issues or opinion's on the situation? Is there a better throw out bearing out there or should I got to Mopar if South bend wont give me a better one? thanks
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #2 of 5 (permalink) Old 07-05-2010, 05:33 PM
Do you know if there is any sort of warranty still on the clutch? If it is the throw-out I wouldnt drive on it too much longer before you get it fixed.
Carbur8tr is offline
post #3 of 5 (permalink) Old 07-06-2010, 12:46 PM Thread Starter
milkin cowboy
no shes parked just drove it home,Thanks
KEEP ON KEEPIN ON
post #4 of 5 (permalink) Old 07-07-2010, 03:59 PM
I dont know about southbend but I know whenever I did mine I ended up replacing my flywheel. The one I got has an upgraded throughout, this is it. Just something to look into plus its really not that much.
post #5 of 5 (permalink) Old 07-07-2010, 07:48 PM
91/2 7.3idi's Avatar
Send a message via AIM to 91/2 7.3idi
call southbend they are great people
Nick
91 f-250 xcab,long bed,7.3 idi(soon to be a dt 360) 5 speed, 33's, pump turned up, ultra-lite gauges and 6 inch flat black miter cut stacks. coming soon:turbo and intercooler.
97 gmc 2500 2x4 6.5 turbo 5 speed. k&n intake and muffler cut off. gone but not forgotten
01 gmc 2500hd duramax xcab long bed 4x4. straight piped
91/2 7.3idi is offline
Looking for a South Bend 97_redstroke Supporting Vendors Forum 2 05-26-2010 11:37 AM
south bend clutch dodgetheonlytrk 5.9L Cummins (1998.5-2002) 5 12-02-2009 07:07 PM
south bend 03 dodge man 5.9L Cummins (2003-2007.5) 13 04-17-2007 06:03 AM
South Bend Clutch Squatch 2003-2007 6.0L Power Stroke 7 01-05-2007 12:11 AM
