6 speed fluid - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MILKINGCOWBOY, this thread has received 7 replies and been viewed 1401 times.
post #1 of 8 (permalink) Old 07-08-2010, 01:41 PM Thread Starter
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
6 speed fluid
Besides the factory fluid. What have you guys been running? How has it worked? How long have you been using it? What has not worked? I don't have a problem buying the factory stuff. I just had 1 tranny fail before with it in it and did not know if there was something better to use.
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #2 of 8 (permalink) Old 07-09-2010, 03:58 PM
Running AMSOIL in them. No issues or complaints from the 2 guys using it that bought from me.
01quadcab is offline
post #3 of 8 (permalink) Old 07-09-2010, 04:08 PM
BUCK2's Avatar
Royal purple makes a fluid for them as well, I am running it in my NV4500
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
post #4 of 8 (permalink) Old 07-09-2010, 04:32 PM
Amsoil for me, about 20k now
Carbur8tr is offline
post #5 of 8 (permalink) Old 07-10-2010, 07:42 PM
Ghost
Phily's Avatar
Amsoil.
Phily is offline
post #6 of 8 (permalink) Old 07-11-2010, 07:15 PM
Professional Grouch
Live Oak's Avatar
I use Pennzoil Synchromesh. It is MS9224 rated and a direct replacement for the OEM fluid and MUCH MUCH cheaper.
Has worked very well for me for the past 7 years.
I bought mine from the Yahoo Oil Store in the 5 gallon pail since I am maintaining 2 Dodge Cummins 6 speed trucks.
http://oilstore.stores.yahoo.net/pensyn5gal.html
Mine-2002 2500 SLT Laramie, 4x4, ETH/DEE, F1 Mach 1.6 injectors, Edge EZ, Cummins eBrake, Air Dog 150, ISSPRO Gauges,BHAF, Outterware Prefilter, heat shield, DSS, Dark Garnet Red, 3.54 diff. gears, Westin Sportsman Brush Guard, Westin Sportsman Nerf Bars, Rhino Liner, White Night backup Light, 295/75R-16's, Passport 8500i radar/laser detector. NRA Benefactor Life Member, NAHC, NSSA, NSCA Life Member, RWVA Member
Hers-2001.5 2500 SLT Laramie, 4x4, ETH/DEE, 3.54 diff. gears, Vulcan 1/2" Big Line Kit w/frame relocated Aertex lift pump, ISSPRO fuel pressure gauge, Side Trax Nerf Bars, Bed Liner, B&W Turnover Ball Hitch, Delta Aluminum Bed Box, Design Tech 50 watt backup lamps.
Live Oak is offline
post #7 of 8 (permalink) Old 07-12-2010, 01:35 PM Thread Starter
milkin cowboy
thanks, do you work your trucks hard?
KEEP ON KEEPIN ON
post #8 of 8 (permalink) Old 07-18-2010, 05:32 PM
I use AMS in mine too. pull an older 30' 5th. lots of 8% or better grades.
Thundercraft is offline
The Following User Says Thank You to Thundercraft For this addition to TDG:
MILKINGCOWBOY (07-21-2010)
7 speed spicer to a 9 SPEED EATON/FULLER bayou hotshot Medium and Heavy Duty 6 01-21-2010 10:06 PM
Front/Rear end and 5-speed fluid capcities ParkerFly 1994-2003 7.3L Power Stroke 3 04-06-2008 04:04 AM
6 speed transmission fluid dieselfreak 5.9L Cummins (1998.5-2002) 2 08-15-2007 05:30 AM
Allison 1000 5-Speed to 6-Speed Conversion stevebos GM Transmissions 8 01-09-2007 06:21 AM
High speed sometimes low speed vibration masonjo 5.9L Cummins (1998.5-2002) 2 11-08-2006 02:27 PM
