truck died while driving down the interstate - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dodge22racing, this thread has received 5 replies and been viewed 3968 times.
post #1 of 6 (permalink) Old 07-10-2010, 11:11 PM Thread Starter
98.5 24 valve drove 500 miles and died out of nowhere...fired up with ether after sitting for about 20 minutes...fuel pressure is 13psi with FASS...not my truck...friends dads
Dodge22racing
1998 Ram Quad Cab 2500 12 Valve, 4 inch exhaust...5inch tip...BD digital guage displays Trans,Pyro,Post...no mods yet
dodge22racing is offline
post #2 of 6 (permalink) Old 07-10-2010, 11:16 PM Thread Starter
fired up and is driving...curious if anybody has had this problem or heard of anything like this
Dodge22racing
post #3 of 6 (permalink) Old 07-11-2010, 01:04 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
check the filters and fuel lines. Make sure the lines are also not where they can get real hot.
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #4 of 6 (permalink) Old 07-11-2010, 07:09 PM
Professional Grouch
Live Oak's Avatar
I would suggest your friend take the truck somewhere to check for what if any DTC codes may be stored in the ECM/PCM.
At least it will give an idea of where to start troubleshooting as I think this problem my rear its ugly head again in the future.
It could be the VP-44, APPS, loose connectors, grounds, etc. Get the codes first and then procede from there.
Mine-2002 2500 SLT Laramie, 4x4, ETH/DEE, F1 Mach 1.6 injectors, Edge EZ, Cummins eBrake, Air Dog 150, ISSPRO Gauges,BHAF, Outterware Prefilter, heat shield, DSS, Dark Garnet Red, 3.54 diff. gears, Westin Sportsman Brush Guard, Westin Sportsman Nerf Bars, Rhino Liner, White Night backup Light, 295/75R-16's, Passport 8500i radar/laser detector. NRA Benefactor Life Member, NAHC, NSSA, NSCA Life Member, RWVA Member
Hers-2001.5 2500 SLT Laramie, 4x4, ETH/DEE, 3.54 diff. gears, Vulcan 1/2" Big Line Kit w/frame relocated Aertex lift pump, ISSPRO fuel pressure gauge, Side Trax Nerf Bars, Bed Liner, B&W Turnover Ball Hitch, Delta Aluminum Bed Box, Design Tech 50 watt backup lamps.
Live Oak is offline
post #5 of 6 (permalink) Old 07-15-2010, 07:34 PM
Singles Club Member #34
Send a message via Yahoo to dslrunner86
I had the same thing happen on my 99' it turned out my apps was going bad problem was it killed my VP44 when it went.
1999 dodge 2500 24v ext cab long bed 4x4, nv4500 w/a LUK clutch, 5" straight pipe to 6" stacks, Red Oak Diesel VP44, holley black lift pump and big line kit, edge juice w/ attitude, RV275's, Modified intake horn and plate, Lock-N-Stich'd 53 Block, BHAF, no silencer, 06' 17" rims w/ 295/70/17 nitto terra grapplers.
Walking V & HILBILLY INC.
dslrunner86 is offline
post #6 of 6 (permalink) Old 07-24-2010, 01:45 PM
ADMIN/MAFIA
neeltburn's Avatar
Roll your key on and off (not starting the truck) on the 3rd time leave it in the run position. your codes will be displayed in the odometer. Just a guess but Im gonna say lift pump and possible injection pump. (learned this the hard way) Codes will give us the codes if there are any there.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
truck died while driving down the interstate dodge22racing 5.9L Cummins 12 Valve (1994-1998.5) 2 07-11-2010 04:09 AM
Truck died while driving? I'm confused.... Sader123 2003-2007 6.0L Power Stroke 6 08-27-2007 10:57 PM
Truck died while driving, CPS? imported_99powerstroke 1994-2003 7.3L Power Stroke 10 07-11-2007 06:06 PM
Driving along and died deerrun 2003-2007 6.0L Power Stroke 5 01-28-2007 02:09 AM
