Looking for a new turbo - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dslrunner86, this thread has received 10 replies and been viewed 1840 times.
post #1 of 11 (permalink) Old 07-15-2010, 07:39 PM Thread Starter
Singles Club Member #34
Send a message via Yahoo to dslrunner86
Im still running my stock hx35 but its starting to get tired and my temps are around 1150 max when towing up a grade and was curious as to what would be a good replacement for it. Im 70% no laod 30% towing with the truck.
1999 dodge 2500 24v ext cab long bed 4x4, nv4500 w/a LUK clutch, 5" straight pipe to 6" stacks, Red Oak Diesel VP44, holley black lift pump and big line kit, edge juice w/ attitude, RV275's, Modified intake horn and plate, Lock-N-Stich'd 53 Block, BHAF, no silencer, 06' 17" rims w/ 295/70/17 nitto terra grapplers.
Walking V & HILBILLY INC.
dslrunner86 is offline
post #2 of 11 (permalink) Old 07-16-2010, 02:19 AM
SSpeeDEMONSS's Avatar
if you are only pulling 1150 up a grade then an S300G would be a good little upgrade. super B, same thing. heck, even just a compressor upgrade and drill out the wastegate would be good.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
The Following User Says Thank You to SSpeeDEMONSS For this addition to TDG:
dslrunner86 (07-19-2010)
post #3 of 11 (permalink) Old 07-16-2010, 05:11 PM
How much would it be for a compressor upgrade? Also drill out the wastegate.... how so
Carbur8tr is offline
post #4 of 11 (permalink) Old 07-16-2010, 11:49 PM
the s300 super b is a good choice or something similar it will handle a lot of abuse.
01quadcab is offline
post #5 of 11 (permalink) Old 07-18-2010, 05:48 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Drilling the wastegate is free, The only thing you gotta do is take off the turbo and loosen the 6bolts and hold back the flap and drill thru. and the compresser wheel maybe 100 and some. but im not sure on that.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #6 of 11 (permalink) Old 07-19-2010, 07:27 PM Thread Starter
What about piers modified hx40 or a super phat shaft?
post #7 of 11 (permalink) Old 07-19-2010, 10:50 PM
here's drilling out the divider.
https://thedieselgarage.com/forums/showthread.php?t=1578
here's the compressor upgrade.
theres another place that sells it for cheaper i believe but i dont remember. ask in the supporting vendors section.
http://www.htturbo.com/cu.htm
post #8 of 11 (permalink) Old 07-22-2010, 07:55 AM
The pdr hotrod 40 has a really punchy power band. It lags a bit, then comes on hard and fast in my experience. The large exhaust housing doesn't help unless you have the fuel to spool it. A super fat shaft is a variation of the s300, but even those, as small as a 62, will still lag quite a bit.
Honestly, if you are only turning 1150deg. at the manifold, anything other than a stocker, he351, 35/40 hybrid, or 57mm s300, probably won't spool fast enough for you, and isn't going to gain you anything. That is, unless you plan on adding more fuel down the road.
post #9 of 11 (permalink) Old 07-22-2010, 08:08 AM
S300G would probably be perfect unless you have bigger plans.
if you could get an ETT60/65/12, that would be the ultimate basic HP, quick spool turbo.
post #10 of 11 (permalink) Old 07-22-2010, 07:15 PM Thread Starter
Thanks for the input guys I think im gona go with the s300 as soon as my bonus get here. This rig isnt gona be anything but my daily driver/race truck & pull truck hauler.
Isspro Turbo monitor or Turbo timer proud1 1994-2003 7.3L Power Stroke 4 03-11-2010 11:46 PM
7.3 turbo wanted for 1991 pre turbo rwbmaine Whats Been Sold 0 05-24-2009 10:45 PM
1991 Ford 7.3 Non Turbo I Need To Figure Out How To Turbo It blacksmokeobs 7.3L and 6.9 IDI (Pre 1994) 7 04-01-2009 12:51 AM
Wanted: Early 99 PSD Turbo Pedistal with or without turbo. WyoDieselCowboy Whats Been Sold 3 04-22-2007 09:20 PM
Very oily tube post turbo. Means Bad turbo seals? I10HaulR 2003-2007 6.0L Power Stroke 1 03-07-2007 10:59 PM
