edge juice and straight pipe +low fuel psi =no smoke? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Superstroker, this thread has received 14 replies and been viewed 7494 times.
post #1 of 15 (permalink) Old 07-18-2010, 02:19 AM Thread Starter
Superstroker's Avatar
Ok so I know that diesels can smoke and how they work and I dont do it to piss off people or to waste diesel fuel, I just want to smoke every now and then but I have a 99 24v with a built automatic trans.
I have edge juice with attitude on level 5, straight pipe, silencer ring removed(which does nothing but make it louder, i know and i love it) but when I mash down on the pedal taking off or just rolling down the highway to pass i have no smoke. I do however notice that my Fuel psi is dropping to around 3psi at WOT and I noticed it and dont mash the pedal anymore and have since ordered and Airdog pump. Am I not getting any smoke bcause i dont have enough fuel to make the correct hp and to smoke? I will be installing the airdog tuesday or wednseday so that will hopefully fix the fuel psi problem.. the vp44 pump was rebuilt at 88,000 miles and the truck has 155,000 on it.
Please let me know whats going on.. Thanks
Matt
1999 24v ext cab quad cab long bed Laramie 4x4 : 155k miles, straight piped, Edge Juice w/ Attitude, "Dr Evil" trans rated for 800hp with 2500 stall gear driven TC, airdog 100, 2" leveling kit 33" mastercrafts.
Avatar is before I bought it of course. new pic coming soon
SOLD: 2006 F250 6.0 EXT CAB SBSCT by DFUSER,INNOVATIVE,: 2003 turbo :4inch cool duals and 6inch tips: HP Intake elbow: ARP STUDS: Diprocol Boost, Pyro, Trans, Fuel Pressure guage in quad pod: Isspro EOT guage in dash bezel: HID 6000k Headlights:305/40r22 on ProComp Extreme black and aluminum wheels: 2008 Mirrors,Tailgate, taillights and bumper: Sir Michaels Roll Pan: Billet fuel and Oil Caps:Billet grille: Billet tow hooks:Kenwood Double Din: Acetoned badges:
Superstroker is offline
post #2 of 15 (permalink) Old 07-18-2010, 05:30 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
If your getting 3psi at WOT, i'd say your lift pump and injection pump are dead (no good) Who rebuild that pump for you?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 15 (permalink) Old 07-18-2010, 02:22 PM Thread Starter
Diesel injection a local shop it was done it 06 at 88k miles and its clocking 156k miles now.
post #4 of 15 (permalink) Old 07-18-2010, 11:55 PM
do you have your prefuel settings turned up on the juice? and yes you need fuel to make smoke.
01quadcab is offline
post #5 of 15 (permalink) Old 07-19-2010, 03:41 AM
And also when you start your truck up, do you let it sit for a few seconds or do you just take off when started up?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #6 of 15 (permalink) Old 07-19-2010, 07:10 PM
Singles Club Member #34
Send a message via Yahoo to dslrunner86
id say your lift pump is definatly done. air dog is a good choice hopefully you cought it before you killed the VP they love there fuel pressure. On a side note like 97cummins asked do you warm it up before u drive it that is rather important on the 99s cause of the 53 blocks i unfortunatly found that out the hard way no i let it get to 140 before i move it.
1999 dodge 2500 24v ext cab long bed 4x4, nv4500 w/a LUK clutch, 5" straight pipe to 6" stacks, Red Oak Diesel VP44, holley black lift pump and big line kit, edge juice w/ attitude, RV275's, Modified intake horn and plate, Lock-N-Stich'd 53 Block, BHAF, no silencer, 06' 17" rims w/ 295/70/17 nitto terra grapplers.
Walking V & HILBILLY INC.
dslrunner86 is offline
post #7 of 15 (permalink) Old 07-21-2010, 12:46 AM Thread Starter
well I looked on my block and nowhere does it say 53.. and i dont let it warm up very much.. maybe 2 minutes..
post #8 of 15 (permalink) Old 07-21-2010, 01:20 AM
My guess is, that the edge worked the lift pump too hard and fried it and is slowly working the injection pump. How do you have your fuel system set up? Like a snubber at the pump and the sending unit screwed in the snubber?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
post #9 of 15 (permalink) Old 07-21-2010, 01:30 PM
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
Check the low end settings on the juice, Also 3psi is not enough to do much with and I would not be surprised if the VP is going to go soon. Also is the VP wire tapped for the Edge that will make a difference too
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #10 of 15 (permalink) Old 07-21-2010, 07:19 PM
Do you leave it on level 5 all the time? Also did you put everything on yourself such as the edge and the programmer and etc.? And one more question, is there an white smoke or a dead pedal?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
cptrucks.com
Straight Pipe Powerstroke85 2003-2007 6.0L Power Stroke 4 04-02-2009 02:27 PM
Straight pipe - Cat? converter 1994-2003 7.3L Power Stroke 15 04-26-2008 06:47 PM
straight pipe or not dieselboy 6.2L Diesel Engine 11 10-19-2007 02:28 AM
straight pipe 4in or 5 in jackerman Whats Been Sold 0 11-15-2006 12:37 AM
4in straight pipe 01dezoll 5.9L Cummins (1998.5-2002) 5 11-13-2006 01:41 PM
