shaking problem Im lost help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gwelding, this thread has received 5 replies and been viewed 831 times.
post #1 of 6 (permalink) Old 07-19-2010, 01:08 AM Thread Starter
I have a 1998.5 dually 4x4, 250,000 miles, edge programer, 40hp injectors, fass fuel, about it, I run a 235/85/ r16 tire.
I have a front end shake when I apply the brake so I turned the rotors, still have it. tie rods were pretty bad so we replaced them had it realigned and still does it. Found a little play in the ball joints so I replaced them along with the wheel bears, a new set of rotors, calipiers, brakes , brake lines , shocks, and power steering gear box, upper and lower control bushings, they were all wore well, had it realigned I still have it now i feel it going down the road a little so I replaced the tires no luck. Could it be the axle shafts? Its really bad when you apply the brakes so bad Im afraid to haul anything with it and amost drive it. Any ideas?
Dodge 1998.5 ext.cab 4x4 24 valve. dually edge , 40hp ,injectors, fass, bhaf
gwelding is offline
post #2 of 6 (permalink) Old 07-19-2010, 07:14 PM
Singles Club Member #34
Send a message via Yahoo to dslrunner86
Have you replaced the track bar those will cause that to happen and before to long it gets really bad. I believe theres a thread on it in here some where.
1999 dodge 2500 24v ext cab long bed 4x4, nv4500 w/a LUK clutch, 5" straight pipe to 6" stacks, Red Oak Diesel VP44, holley black lift pump and big line kit, edge juice w/ attitude, RV275's, Modified intake horn and plate, Lock-N-Stich'd 53 Block, BHAF, no silencer, 06' 17" rims w/ 295/70/17 nitto terra grapplers.
Walking V & HILBILLY INC.
dslrunner86 is offline
post #3 of 6 (permalink) Old 07-20-2010, 12:15 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Have you check the master cylinder and portioning valve?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #4 of 6 (permalink) Old 07-21-2010, 12:11 PM
Official TDG Doctor
hccumminssmoke's Avatar
track bar, ball joints, wheel bearings...
Nate
hccumminssmoke is offline
post #5 of 6 (permalink) Old 07-22-2010, 05:09 PM Thread Starter
I think your right with the master cylinder. thanks
gwelding is offline
post #6 of 6 (permalink) Old 07-23-2010, 03:39 AM
mdcody101's Avatar
track bar
2011 F350 6.7
mdcody101 is offline
Truck is Shaking Bad 03RescueDiesel 2003-2007 6.0L Power Stroke 7 09-12-2009 04:59 AM
Truck is shaking 03RescueDiesel 2003-2007 6.0L Power Stroke 1 07-06-2009 02:44 AM
Lost Your Job? Return Your New Car <no problem> bushpilot The Parking Lot 16 01-07-2009 01:16 AM
shaking @ 55 to 65 mph thehammer 1994-2003 7.3L Power Stroke 11 11-29-2007 11:24 PM
Shaking quickie Duramax 2004.5-2005(LLY) 2 04-09-2007 01:52 PM
