CEL and fuel pump timing gear? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by SSpeeDEMONSS, this thread has received 8 replies and been viewed 1311 times.
post #1 of 9 (permalink) Old 07-22-2010, 12:36 AM Thread Starter
SSpeeDEMONSS's Avatar
my friends truck threw a CEL, when he checked it it said fuel pump timing gear. i have never heard of that before. what does that mean?
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #2 of 9 (permalink) Old 07-22-2010, 05:34 AM Thread Starter
He said it runs normal but sometimes it doesn't have power like it doesn't have fuel.
post #3 of 9 (permalink) Old 07-22-2010, 07:50 AM
Did he tell you a Pcode? Their are fuel injection timing error codes, p0216, p01690 would be the most likely. Even when running my pump gear mechanically advanced, p1690 was the only code I threw. Did he recently pull the pump gear for any reason? If he damaged the keyway during re-install, that could have caused the code.
post #4 of 9 (permalink) Old 07-22-2010, 09:16 PM Thread Starter
no, nothing has been pulled apart. i think its bone stock. if its not it has very little done to it. not many miles on it either.
post #5 of 9 (permalink) Old 07-22-2010, 09:19 PM Thread Starter
he said he thinks he remembers see P216, so maybe he say P2016. what would that mean?
post #6 of 9 (permalink) Old 07-23-2010, 06:22 PM Thread Starter
yup, P0216. whats that mean?
post #7 of 9 (permalink) Old 07-24-2010, 05:35 PM
Internal Injection pump timing failure. The timing solenoid gets worn out, and the pump can no longer reach full advance. Its hard to say how long it will last with that code present before giving up the ghost.
post #8 of 9 (permalink) Old 07-24-2010, 07:12 PM Thread Starter
can the solenoid be changed or does the whole VP need to be replaced?
post #9 of 9 (permalink) Old 07-25-2010, 04:58 PM
You need to replace the whole VP44 injection pump. I did mine about 6 months after I got that code. I had to save some money because they are not cheap. I wnet with bluechip because he has the best knowledge imo from what I found out from others around my area who delt with him. He shipps them all over the country. I haven't had a problem with my truck since. I just mad sure u put a FASS pump on my truck before I replaced it.
cumminsdude2001 is offline
92' 7.3 injection pump gear timing [email protected] 7.3L and 6.9 IDI (Pre 1994) 4 03-02-2010 02:41 AM
advice needed cummins fuel gear pump CLC379 Medium and Heavy Duty 5 10-29-2009 09:27 PM
Timing gear upgrade and lift pump SneakyPete 6.2L Diesel Engine 0 11-06-2007 12:40 PM
Help Please, Fuel Pump Timing DT466 nimmo Medium and Heavy Duty 11 05-13-2007 02:45 PM
timing the pump Darvin 5.9L Cummins 12 Valve (1994-1998.5) 2 10-28-2006 11:54 AM
