Injector Pump ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by hdcolo, this thread has received 3 replies and been viewed 858 times.
post #1 of 4 (permalink) Old 07-23-2010, 12:30 AM Thread Starter
Injector Pump ?
. Been having a strange problem for some time and have replaced just about everything and still does it. . 2002 - 2500 automatic. . Runs great for about forty five minutes then developes a momentary power drop when holding a steady speed. . . . It will momentarily loose power then pick right back up. . Does this at regular 6 or 7 second intervals. . Will excellerate beautifully then resume it's pausing again when you level off at a steady speed again. . . .
TPS replaced three years ago. .
Manifold pressure sensors replaced six months ago. .
Trans transducer replaced two years ago. .
ECU replaced this year. .
Has two transfer pumps, pressure is actually a bit high. . . . .
hdcolo is offline
post #2 of 4 (permalink) Old 07-23-2010, 03:38 AM
mdcody101's Avatar
if you change you crusing speed does it not happen?
2011 F350 6.7
mdcody101 is offline
post #3 of 4 (permalink) Old 07-23-2010, 04:08 PM Thread Starter
Yup. . Does not do it while excellerating but no matter what speed you level off at it does it. .
hdcolo is offline
post #4 of 4 (permalink) Old 08-16-2010, 08:17 PM
SmokinCustoms's Avatar
check your cam sensor
SmokinCustoms is offline
I need an injector pump and a lift pump for a 98.5 24valve CRAZY ROB Whats Been Sold 7 07-01-2009 11:15 PM
Injector Pump and Lift Pump are toast. Now What? 6thFrame 5.9L Cummins (1998.5-2002) 21 05-19-2009 09:32 PM
injector pump ddbc 7.3L and 6.9 IDI (Pre 1994) 8 12-17-2007 01:27 AM
Injector Pump? powerstroker97 1994-2003 7.3L Power Stroke 5 10-09-2006 01:36 AM
