Engine cutting out - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99Cummins24V, this thread has received 2 replies and been viewed 954 times.
post #1 of 3 (permalink) Old 07-24-2010, 03:33 AM Thread Starter
Engine cutting out
i have a 99 24V with factory nozzles, BHAF intake, Straight Pipe, and a Programmer. Going down the road with a load on the Engine will cut out for a split second the right back on top. It only did it once in a while now it is getting worse. Does not matter what speed only under acceleration. It is much worse under hard acceleration. It does it very very little with no load but hard acceleration. I hope this makes sense. Please help.
99Cummins24V is offline
post #2 of 3 (permalink) Old 07-24-2010, 05:30 PM
Have it scanned for codes. That is the best place to start, then go from there, based on the way you are describing it, I would start looking at your crank position sensor.
post #3 of 3 (permalink) Old 07-28-2010, 02:06 PM Thread Starter
Will my scanner on my programmer pick them up?
?Why is it cutting off? jonesy 1994-2003 7.3L Power Stroke 22 04-16-2012 05:19 AM
Engine Fan Cutting in all the time?? 06kma 2003-2007 6.0L Power Stroke 3 06-14-2010 02:27 AM
Engine Cutting out while driving. shamrock13 1994-2003 7.3L Power Stroke 6 03-29-2009 02:44 AM
Engine cutting out need help moboy 7.3L and 6.9 IDI (Pre 1994) 11 12-14-2007 03:10 PM
Engine Cutting out imported_BigGreen 1994-2003 7.3L Power Stroke 8 11-02-2006 12:01 PM
