Battery Cable replacement - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by veritas42, this thread has received 3 replies and been viewed 4240 times.
post #1 of 4 (permalink) Old 07-24-2010, 11:00 AM Thread Starter
Ok guys I have put off replacing my battery cables long enough. They are absolutely corroded. They popped off when pulling out of the driveway and killed the truck for a sec. My question is can I get the cables already to rock and roll oem style somwhere? It seems like if I replace the end the cable will be to short. I am in the middle of a move right now so I want to replace them as painlessly as possible (I have very little time right now). Anyhow it looks fairly straightforward, any tricks I should know? Again thanks for your help I am stretched for time right now and don't wanna go to a shop. If need be I might be able to replace cables making my own. Just looking for all my options.
01 2500, quad cab, 2wd, auto, 132k, turbo rebuilt good as new by htt , and 0216 code for 1 1/2 years now. Airdog 100 fuel system after 3 stock lift pumps.
veritas42 is offline
post #2 of 4 (permalink) Old 07-24-2010, 01:36 PM
ADMIN/MAFIA
neeltburn's Avatar
We have an auto parts store here that can make cables to any size or spec you need. I would try specialty auto shops not your Auto Zone chains. You might call Napa and see if they make them to spec.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 4 (permalink) Old 07-24-2010, 03:26 PM Thread Starter
Ouch
Well, Napa told me they only carry the negative cables. The Stealership!!! wanted $175, for the left side and $199 for the right side positive. Looks like a different route for me!!!!
post #4 of 4 (permalink) Old 07-24-2010, 03:39 PM
ADMIN/MAFIA
neeltburn's Avatar
Call shops that rebuild starters and alternators in you area, someone will make a custom to spec cable WAY cheaper..
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
12v throttle cable replacement 4cstr Dodge - Modification instructions, Product installs and Tech Articles 1 01-12-2013 02:34 AM
Battery Replacement max 2003-2007 6.0L Power Stroke 29 01-05-2010 03:59 PM
Battery cable install help JoeBob1901 1994-2003 7.3L Power Stroke 1 01-31-2008 11:56 PM
Battery Cable Layout genie144 1994-2003 7.3L Power Stroke 0 08-23-2007 10:37 PM
rear pad replacement & brake cable how to aldo_45030 1994-2003 7.3L Power Stroke 0 06-04-2007 01:35 PM
