99 wont start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bsutton2000, this thread has received 5 replies and been viewed 1061 times.
post #1 of 6 (permalink) Old 07-25-2010, 09:27 PM Thread Starter
99 wont start
We got 3 codes P0252 P1693 P1694 If we let it spin over for 15 seconds it will start run like garbage then straighten out
bsutton2000 is offline
post #2 of 6 (permalink) Old 07-26-2010, 06:03 PM
It almost sounds as though your vp might be going out. The 93 and 94 are communication errors. I dont know about the 52 code, may have been a 53 but you dont want anything in that area, just bad news from there.
Check you fuel pressure and see what you get. Also take a look at the vp diagnostic sticky.
Carbur8tr is offline
post #3 of 6 (permalink) Old 07-28-2010, 04:22 PM
If you run it for a minute little you are saying, then shut it down will it start back up? Sounds to me like, your cascade valve is stuck open, and fuel is draining back out of the lines. So in essence, everytime you go to start the truck, you have to re-prime the lines and bleed all of the air out before it will run like normal.
post #4 of 6 (permalink) Old 07-31-2010, 12:51 AM Thread Starter
yes it will start right back up
post #5 of 6 (permalink) Old 07-31-2010, 05:05 PM
Sounds like the Cascade valve is draining back. Have you noticed if the problem still persists or improves at all if you park with the truck facing down hill?
post #6 of 6 (permalink) Old 10-24-2010, 10:26 PM Thread Starter
put new lift pump on and injector pump now it runs fine but turns over twice before it starts Lift pump bad or injector pump bad?
help wont start again voncheese 2003-2007 6.0L Power Stroke 2 01-02-2010 03:35 AM
wont start bsutton2000 1994-2003 7.3L Power Stroke 0 09-04-2009 09:49 PM
wont start southtexasidi 1994-2003 7.3L Power Stroke 4 08-08-2009 04:01 PM
