Parking brake - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Carbur8tr, this thread has received 3 replies and been viewed 1115 times.
post #1 of 4 (permalink) Old 07-26-2010, 12:37 AM Thread Starter
Parking brake
Well tried looking in my haynes book today to see if there was something on adjusting the parking brake but all I can find is the adjustment for the trucks with rear drum brakes and I have the disc brakes in the back. Just wondering if anyone had any suggestions or even a possible write up. Anything would help I can mash the thing to the floor right now and with a trailer its like nothings holding it back from rolling.
Carbur8tr is offline
post #2 of 4 (permalink) Old 07-27-2010, 07:22 PM
Singles Club #2
smokndiesel7588's Avatar
I have discs in the rear as well. The easiest way I've found to adjust the parking brake is to remove the caliper and rotor. You will see an adjustment knob inside there. It is connected to the pads and can be adjusted with your fingers. I forget which way you have to twist it to push the pads outward, but you will be able to see it move as you twist the knob. Don't adjust it too much at a time or you'll find out that the disc wont go back on easily. This is caused by the parking brake pads rubbing the inside of the disc. Hope this helps.
Greg
smokndiesel7588 is offline
post #3 of 4 (permalink) Old 07-27-2010, 10:44 PM Thread Starter
Is this for both wheels in the back or just the drivers side?
post #4 of 4 (permalink) Old 07-29-2010, 11:14 PM
Singles Club #2
both wheels need adjustment usually...its the same process for both sides
Greg
topkick parking brake magnumtow Medium and Heavy Duty 7 06-17-2012 12:53 AM
parking brake Help Superstroker123 General Ford Truck and Excursion 10 01-04-2010 11:54 PM
Parking Brake Help neeltburn 1994-2003 7.3L Power Stroke 6 10-07-2009 11:19 PM
parking brake SmokeyMtnKid 1994-2003 7.3L Power Stroke 3 07-18-2007 11:21 PM
Parking brake adjustment? ACC inc. General Ford Truck and Excursion 2 02-26-2006 06:32 PM
