6 speed trans temp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by MILKINGCOWBOY, this thread has received 1 replies and been viewed 952 times.
post #1 of 2 (permalink) Old 07-31-2010, 01:39 PM Thread Starter
milkin cowboy
MILKINGCOWBOY's Avatar
Send a message via AIM to MILKINGCOWBOY
6 speed trans temp
What is the normal operating temp for a 6 speed? what is the normal towing temp for a 6 speed? and what is to hot and you start doing damage?
Thanks
2002 3500 6 speed ex. cab 4x4 custom flatbed farm truck 9,120 lbs. light weight ALL WAYS HAULIN HAY, CATTLE OR A-$-$!!!! BHAF,4" OPEN STACKS,EDGE JUICE WITH ATTITUDE, AIR DOG II 100,SOUTH BEND CLUTCH
1982 IH Transtar Eagle 4370 turned up 400 Cummins big cam, straight 6" bull haulers one hell of a
Jake and 13 speed od
White 2-105 tractor with 354 Perkins
White 2-135 tractor with 478 White/Hercules
KEEP ON KEEPIN ON
SUPPORT AMERICAS DAIRY FARMS
http://i17.tinypic.com/4u2drv8.jpg
http://profile.myspace.com/index.cfm...ndid=137814954
MILKINGCOWBOY is offline
post #2 of 2 (permalink) Old 07-31-2010, 02:00 PM
BUCK2's Avatar
You can always add those trans coolers from Geno's. I did to my NV4500. I need to get a gauge but I have not done it yet.
With the coolers it will hold about 2 qrts of additional fluid.
Here are the ones I added and it was easy! http://www.genosgarage.com/prodinfo....er=FC-6-SPD-DG
SINGLES CLUB #211
TEXAS CLUB #5
BUCK2 is offline
Trans temp oil temp guages. . . M123KT-450 General Parts and Accessories 5 08-16-2009 04:57 PM
Trans temp n oil tem temp gauges. . .A-pillar mount... M123KT-450 Supporting Vendors Forum 3 08-14-2009 02:49 AM
Trans Temp GilroyRacing 2003-2007 6.0L Power Stroke 6 03-02-2008 04:55 PM
what temp does your trans run at? jebsurf 1994-2003 7.3L Power Stroke 13 01-17-2008 12:24 AM
trans temp gobigorgohome 2003-2007 6.0L Power Stroke 6 10-05-2007 12:45 AM
