Speaking of Diff problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Carbur8tr, this thread has received 11 replies and been viewed 1812 times.
post #1 of 12 (permalink) Old 08-04-2010, 09:03 PM Thread Starter
Well looks like I got another leak. Crappy pic but any suggestion?
Carbur8tr is offline
post #2 of 12 (permalink) Old 08-05-2010, 12:04 AM
Singles Club #2
smokndiesel7588's Avatar
check to see if you have any play in the driveshaft (up and down where the shaft goes into the differential). I had the same issue and my usual mechanic said to just keep and eye on it. After a while, I was going through 3 quarts of diff fluid per week, then the bearings blew out one day and I had to get a new rear.
If I would have fixed it earlier, it would have just taken a new pinion seal. So ya might want to try that
Greg
smokndiesel7588 is offline
post #3 of 12 (permalink) Old 08-05-2010, 05:18 AM
IDImonsterstack's Avatar
ditto
under the knife for rebuild
IDImonsterstack is offline
post #4 of 12 (permalink) Old 08-23-2010, 02:48 AM
I hope he isn't still your "usual" mechanic...
Thundercraft is offline
post #5 of 12 (permalink) Old 08-26-2010, 10:08 PM
99 cummins
customdeluxe78's Avatar
yeah, pinoin seal, no doubt
99 cummins, 5-speed, edge comp, speedhut guages, fass 150 system, s&b cold air intake, ces two piece manifold, 5 inch straight exhaust with a 6 inch tip, 5 inch superlift, 4:10 gears, dynatrack lock in lock outs, 35x14.50 thornbirds on 16.5x12 mickey tompson classic 2's, alpine head unit, 1600 watt amp, 2 12 inch subs
customdeluxe78 is offline
post #6 of 12 (permalink) Old 11-01-2010, 05:34 AM Thread Starter
I know this is a little old, but has anyone replaced a pinion seal, kinda getting tired of worrying about this thing? What tools are needed and about how long should it take?
post #7 of 12 (permalink) Old 11-02-2010, 10:53 PM
Cummings24v's Avatar
Very easy. No special tools required. Mind as well change the bearing and u joint while you got it all out. cheep
99 2500, NV4500
4" to 5" pipe, custom made
Edge Comp
BHAF
Raptor 150
EGT, Fuel, Turbo, Oil pressure gauges
285x75x16 Destination MT's
2 stroke oil diet
Cummings24v is offline
post #8 of 12 (permalink) Old 11-03-2010, 02:13 AM Thread Starter
Will napa have the bearing as well as the seal? Also what do you usually use to pull the bearing out?
post #9 of 12 (permalink) Old 11-04-2010, 03:15 AM
Dinner's Avatar
Make sure your diff breather is clean and allowing air to vent through it also...
2001 Dodge 2500 4X4: Goerend, TST, Smarty, MVP, BD Rad, Injectors, Two Turbo's, Snow Performance, Supporting Mods...
12.7 @ 108mph Aug 2011
Canadian Club Member #14
Dinner is offline
post #10 of 12 (permalink) Old 11-16-2010, 06:46 PM Thread Starter
What all is involved in changing the bearing?
speaking of double over 379Longhood Medium and Heavy Duty 4 03-04-2010 04:14 AM
rear diff problems????? vader's fury 1994-2003 7.3L Power Stroke 5 05-08-2009 12:08 PM
Drinking and speaking Chobeeman The Parking Lot 8 03-13-2009 04:04 AM
Speaking of Wal*Mart ovruigo The Parking Lot 11 06-07-2006 02:13 AM
OBS 2 Problems 2 diff Trucks Liftedpsd 1994-2003 7.3L Power Stroke 11 05-17-2006 01:02 AM
