block - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by King, this thread has received 6 replies and been viewed 1296 times.
post #1 of 7 (permalink) Old 08-18-2010, 08:08 PM Thread Starter
block
so the past couple days ive noticed a antifreeze smell. didnt think much of it. wel today i changed oil thought id look in to it. I didnt like what i found. What can be done with the cracked blocks?
2013 Ram 3500 Crew 6.7L 6x6 auto
11 Chevy 1500 ext 4x4 5.3L
07 3500 Crew 6x6 6.7L 6spd manual Edge Juice w/attitude, banks ram air box, 4'' exhaust, egr delete, south bend dual disk, boss 9' 2'' power v
Dads Ride 04 3500 Crew 4x4 5.9L Auto Larime 5'' exhaust, air bags
Bros ride 04 3500 Crew 6x6 5.9L Auto Stock
00 3500 Ext cab Dually 3.55 gears, 4'' MBRP, K&N, edge juice w/ attitude, rev maxx stage 4 converter, custom built tranny, Air Dog 150
98 3500 Ext cab Dually 3.55 gears handshaker, 4 into 5 exhust, edge juice w/att, BHAF
86 k2500 5.7 gas 3.73 gears, lock right front, warns,(My Hunting Beater)
King is offline
post #2 of 7 (permalink) Old 08-18-2010, 09:33 PM
SSpeeDEMONSS's Avatar
get rid of it and get a new non-24 short block.
BRING BACK THE OLD TDG!
SSpeeDEMONSS is offline
post #3 of 7 (permalink) Old 08-22-2010, 12:56 PM
ADMIN/MAFIA
neeltburn's Avatar
Are you sure its the block and not the head or the head gasket? Is the truck a 53 block? If so then chances of a cracked block are not out of the question.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 7 (permalink) Old 08-23-2010, 02:39 AM
The 53 block generally cracked near the back on the passenger side. Should be lower on the block & run lengthwise... should see evidence of the leak.
I believe you can get it "stitched" but I believe all option are $$$...
Thundercraft is offline
post #5 of 7 (permalink) Old 11-11-2010, 03:21 AM
yeah unfortunately, i just went thro this. i have a 99 and it cracked at 58,000 miles.
it coseted me 4000 dollars to get a new block and have it rebuilt! **** happens my man. at least you know your not the only one.
davidfast1 is offline
post #6 of 7 (permalink) Old 11-11-2010, 04:50 AM
TDG Mafia Goon
BombDocDiesel's Avatar
Look on your crank case vent cover. Are the first two digits 53? Chances are; they are not. Either way, a blown head gasket is more likely the case. Mine was blown and I had no signs. I noticed when I was removing the head bolts to put in studs.
What did your oil look like? Gray and slimy or milky and thick? I prefer to start with the least expensive causes and work from there.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #7 of 7 (permalink) Old 11-15-2010, 02:32 AM
Cracked blocks aren't out of the question, I have also seen 55 blocks crack as well as the 53. So... Like said above, look at the system a little closer and see what you find. If you are sure the block is cracked, I wouldn't mess with having it stitched. Just buy a new block, a longblock, or a used engine and go from there.
53 block kc04 5.9L Cummins (1998.5-2002) 7 01-17-2010 05:12 AM
EGR block off heavyhaller 2003-2007 6.0L Power Stroke 6 06-30-2009 06:18 PM
swapping 53 block with a 55 block DHenson 5.9L Cummins (1998.5-2002) 16 03-26-2008 12:59 PM
53 block ?'s smokeisfun 5.9L Cummins (1998.5-2002) 5 01-14-2007 06:26 AM
EGR block off duramaxdave Duramax 2001-2004 (LB7) 1 06-19-2006 06:50 AM
