Mistakes made. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by triker888, this thread has received 1 replies and been viewed 1012 times.
post #1 of 2 (permalink) Old 08-18-2010, 10:24 PM Thread Starter
Mistakes made.
Posted this on the DTR website, also.
When I added my DrawStraw I needed a piece of, flexible, fuel line to hook up the return line to the tank. I went to my box of left over hoses and used a piece of (green) fuel line that Aircraft Spruce sells for aviation fuel line. The other day I noticed a leak when the motor was running. I figured the return line came off since I had good fuel pressure at the VP. I'm unable to get under the truck so I took it to a local (real good) mechanic. He told me that the aviation hose had deteriorated and was shot. He put a diesel fuel, certified hose on and all is good, but...........When I picked up the truck I drove straight to the local diesel fueling station. (my low fuel light was on) In the process of pumping the tank full, I heard the fuel get into the filler neck and knew I was close to being full. Well, another customer yelled at me to let me know that fuel was pouring out.(about 3 to 5 gallons) Shut the pump off and drove straight back to the mechanic to find out what was off and/or loose. Upon close inspection he noticed that the top of the Draw Straw was up and out of the tank. He couldn't figure out why it would pop out since he never touched it. (it's been in for approx 2 years). With a little brain storming we finally figured out why. As most of you know the bottom of the tank bulges down and when I installed the Draw Straw I allowed enough length on the Straw for the bulge. When the mechanic reinstalled the tank he used a transmission jack which pushed the bulge upwards, thereby pushing the Draw Straw up and out of it's gasket. Mystery solved
Hope this info helps someone else.
Apparently, aviation gasoline gas lines and diesel aren't compatable.
triker888 is offline
post #2 of 2 (permalink) Old 09-15-2010, 09:07 AM
elijah's Avatar
great post
When I added my DrawStraw I needed a piece of, flexible, fuel line to hook up the return line to the tank. I went to my box of left over hoses and used a piece of (green) fuel line that Aircraft Spruce sells for aviation fuel line. The other day I noticed a leak when the motor was running. I figured the return line came off since I had good fuel pressure at the VP. I'm unable to get under the truck so I took it to a local (real good) mechanic. He told me that the aviation hose had deteriorated and was shot. He put a diesel fuel, certified hose on and all is good, but...........When I picked up the truck I drove straight to the local diesel fueling station. (my low fuel light was on) In the process of pumping the tank full, I heard the fuel get into the fuel filler neck and knew I was close to being full. Well, another customer yelled at me to let me know that fuel was pouring out.(about 3 to 5 gallons) Shut the pump off and drove straight back to the mechanic to find out what was off and/or loose. Upon close inspection he noticed that the top of the Draw Straw was up and out of the tank. He couldn't figure out why it would pop out since he never touched it. (it's been in for approx 2 years). With a little brain storming we finally figured out why. As most of you know the bottom of the tank bulges down and when I installed the Draw Straw I allowed enough length on the Straw for the bulge. When the mechanic reinstalled the tank he used a transmission jack which pushed the bulge upwards, thereby pushing the Draw Straw up and out of it's gasket. Mystery solved
Good for you man! That's great that you were able to solve the mystery of your truck. This post could be a great help to other people that might encounter this kind of case. Anyway, thanks for sharing your story.
elijah is offline
Made in the USA lilpooh The Parking Lot 6 01-02-2010 11:55 AM
Made some mistakes...seat belt exploded! Cummins_Beast 5.9L Cummins (2003-2007.5) 8 05-15-2009 08:56 PM
I made it big DBogo The Parking Lot 11 04-26-2006 03:22 AM
