Having fuel or elect. problems???? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99Cummins24V, this thread has received 4 replies and been viewed 968 times.
post #1 of 5 (permalink) Old 08-20-2010, 05:51 AM Thread Starter
Truck will randomly cut out for a split second under a load. No load it wont do it unless i cram her thru the floorboards. I have heard everything from bad crank sensor, cam sensor, not enough fuel and bad vp44. Where do I go from here. No check engine light, no smoke I am at a loss here. Beating myself over the head.
99Cummins24V is offline
post #2 of 5 (permalink) Old 08-21-2010, 04:06 AM
bmoeller's Avatar
Mine does that. VP got starved when the LP took a Not as bad with running some 2 cycle engine oil in the fuel, but still does it. Slowly getting worse..............
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 5 (permalink) Old 08-21-2010, 10:29 PM Thread Starter
So there really is no way to fix that other then rebuilding the vp then? I wondered if and aftermarket pump like a pureflow raptor would help.
post #4 of 5 (permalink) Old 08-30-2010, 04:22 PM
dodgedevildog08's Avatar
any after market lift pump will help. the manual states that the stock lift pump will pump between 5 an 10 psi to the vp44 when i put a guage on mine it was barly pumping 4 psi of fuel. it is important to remember that the vp44 is lubricated with diesel fuel. that is why running two cylinder oil in your fuels helps lubricate the vp44. the more fuel you can pump to the vp 44 the better, and what fuel you dont use will be returned to the tank by either the return in the vp44 or the return in the head which exits out the back of the head. you cant go wrong with the airdog, its easy to install and filters are cheap.
2001 Dodge Ram 2500 / 4x4 / Crewcab / 47RE auto trans / Smarty S-03 programmer / Airdog 150
dodgedevildog08 is offline
post #5 of 5 (permalink) Old 08-31-2010, 02:02 AM
You do realise that all these engines in a Freightliner class 5 and 6 do not have a lift pump in the tank. Just a thought!
Also the best fuel for lubricity was the 2% bio, and seeing as most every fuel supplier adds Bio to there fuel as a Cetain booster, and the fuel with 2 cycle oil was not as good as the 2%, did I miss the test that said that bio and 2 cycle is better?
Johnp3 is offline
EGT Elect. Sensor & Gauge?? tcr1016 5.9L Cummins 12 Valve (1994-1998.5) 8 09-24-2009 01:03 PM
Fuel problems Jamison 5.9L Cummins (1998.5-2002) 23 02-18-2008 08:22 PM
6.5L Fuel Problems mthomp214 6.5L Diesel Engine 16 11-05-2007 04:52 PM
02 F150 elect. problems weasel79 General Gas Vehicle 1 06-06-2007 03:37 AM
Fuel problems 02sprtcumns 5.9L Cummins (1998.5-2002) 11 01-14-2007 06:39 AM
