Lift Pump Culprit? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Johnboy11-1, this thread has received 3 replies and been viewed 1021 times.
post #1 of 4 (permalink) Old 08-24-2010, 01:20 AM Thread Starter
Johnboy11-1's Avatar
Question Lift Pump Culprit?
Hi Fellas,
Today my truck let me down for the first time. The truck has been running like a scalded dog (only when I throw the water at it ).
I was turning up a hill and the truck suddenly became sluggish and died almost immediately after. She would not refire. The passenger ran to our shop down the road, grab some famous "Red Fuel" to dump in the tank just to make sure the fuel gauge wasn't broken but no dice.
I checked the inlet line on the VP44 for pressure and only dribbles came out. I tried turning the key, stater bump to prime. The fuel filter resevior would not fill even with the cap off. I tried to dump fuel directly into the filter housing, replaced the filter and tried again. No bueno.
I am currently NOT running a Low Pressure light but that will VERY soon change. This is still the stock lift pump. Are these symtoms of a bad lift pump? ...or?
Any ideas would greatly be appreciated.
Thanks!
Johnboy11-1 is offline
post #2 of 4 (permalink) Old 08-25-2010, 03:15 AM Thread Starter
Just an update;
I tried the lift pump again after sitting overnight. The truck would still not start but the lift pump did prime with the cap off and fuel ran all over the place. I pressed the pressure test outlet and air came out then the red fuel. I tried starting the motor but it would not fire. I'm begining to think that the lift pump went bad (low pressure) and that it wrecked my injection pump.
post #3 of 4 (permalink) Old 08-25-2010, 11:40 PM
jammin60's Avatar
I pm'd you the test procedure for you stock lift pump. hope this helps.
jammin60 is offline
post #4 of 4 (permalink) Old 08-25-2010, 11:51 PM
jammin60's Avatar
also may look at this post had your type of symtoms before it died completely. https://www.thedieselgarage.com/forum...d.php?t=101331
jammin60 is offline
Tags
injection pump, lift pump, stalled, vp44
I need an injection pump and an aftermarket lift pump for my 98.5 24v CRAZY ROB Dodge parts wanted 2 02-10-2010 06:35 PM
I need an injector pump and a lift pump for a 98.5 24valve CRAZY ROB Whats Been Sold 7 07-01-2009 11:15 PM
lift pump??? white01dodge General Dodge Discussion 2 06-30-2009 02:04 AM
Injector Pump and Lift Pump are toast. Now What? 6thFrame 5.9L Cummins (1998.5-2002) 21 05-19-2009 09:32 PM
ACCEL 110GPH Fuel Pump/Lift Pump maxxis_mudder Whats Been Sold 0 12-10-2006 03:24 PM
