Buying my first diesel. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by benson0484, this thread has received 2 replies and been viewed 1102 times.
post #1 of 3 (permalink) Old 08-28-2010, 06:27 AM Thread Starter
I don't know what is a good find or something I should walk away from. I am looking at an 01 four wheeled drive extended cab long bed.
benson0484 is offline
post #2 of 3 (permalink) Old 08-30-2010, 03:54 PM
dodgedevildog08's Avatar
its really hard to tell to by just a short post that you made, if your looking at a 5.9L cummins then the engine is worth its weight in gold. the shape that rest of the truck is going to be the determining factor. my truck is in great shape but i bought it from ohio. so rust can become a big problem, it can make somthing simple like changing ball joints difficult. when i had to change my ball joints which require the removal of the hubs and axels i could not get my hubs free. i had to torch them out and replace it all to include the abs sensors and dust shields. a 400 dollar job turned into a 1800 dollar job just like that and all because of rust. if you can get under her and see what she has up underneath. pay particular attention to things like tie-rod ends, and ball joints, cab and body mounts. little things like this are easy to fix but they take away from money that could be spent elsewhere ie proformance parts, and trust me, building diesel trucks is an addiction, anyone on this forum will vouch for that.
2001 Dodge Ram 2500 / 4x4 / Crewcab / 47RE auto trans / Smarty S-03 programmer / Airdog 150
dodgedevildog08 is offline
post #3 of 3 (permalink) Old 08-31-2010, 10:16 PM
Yeah, I am battling rust as well, and its a pain. I would pass up any truck that has rust. When I bought it, it seemed like it was just some surface rust on the frame, but upon closer inspection over the years as I have crawled all over it, the damage from the rust spread much much further than that. The truck had been repainted prior to the owner I bought it from, and that paint covered up a lot of body rust. It is unbelievable how frustrating that can be. So like mentioned above, be very thorough in looking for rust like you would on any vehicle. And also, pay close attention to the transmission, drivetrain, steering and suspension components.
Also, a good idea to decide now what you are going to use the truck for and what you want out of the truck, and decide accordingly, because each has its own different quirks and problems that need to be checked out.
question on mileage and buying a used diesel duke01genlee 2003-2007 6.0L Power Stroke 50 02-28-2010 11:43 AM
Alright guys got a friend looking into buying 1st diesel SOOTBANDIT 6.5L Diesel Engine 1 12-14-2009 10:24 PM
Buying My First Diesel!!!!!! Help psi_2_high 2003-2007 6.0L Power Stroke 23 01-25-2008 04:47 AM
Tips For Buying a Used Diesel Truck? NateJFH General Diesel 2 03-21-2007 07:41 PM
Thinking of buying a '05 6.0 (first diesel truck) Muskynut 2003-2007 6.0L Power Stroke 23 08-30-2006 12:54 AM
