Edge Comp box - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JUMPSTER93, this thread has received 2 replies and been viewed 5213 times.
post #1 of 3 (permalink) Old 09-08-2010, 09:01 PM Thread Starter
Edge Comp box
How do I adjust the fuel settings on an edge comp box for a 2000 24v? Just bought the truck not too long ago. I have installed a fass system, k&n filter, and a straight pipe. But it will barely blow smoke. Any paperwork out there about the comp box? Thanks
JUMPSTER93 is offline
post #2 of 3 (permalink) Old 09-09-2010, 07:03 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
To adjust power levels 1-5 on the Power Edge Module, push the
corresponding arrow buttons, left arrow will decrease level and right
arrow will increase power level. The levels can be adjusted while the
engine is running
Each power level on the Power Edge Comp has a submenu that allows
the user to tune in the low boost fueling to eliminate excess smoke. To
access the submenu:
a. Be in the power level that you what to adjust the low boost fueling
for
b. Press and hold the round gray button (power button) for about 2
seconds, release button
c. The LED’s will be flashing when in the submenu
d. Use the left and right arrows to adjust the levels 1-5
e. When 1 LED is lit this results in the least responsive setting or
lowest smoke, all 5 LED’s lit is the most responsive
f. Each power level can store a unique submenu setting
g. When accessing the submenu for the first time the LED’s may
appear erratically lit, use the right arrow key to light all LED’s
then set to desired level.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 3 (permalink) Old 09-12-2010, 12:06 AM
Singles Club #2
smokndiesel7588's Avatar
when you installed it...did you do the wire tap on the vp?...if you didnt, it will just act like a 40hp edge box.
Greg
smokndiesel7588 is offline
Edge Comp Box. lbdodge24v 5.9L Cummins (1998.5-2002) 4 01-20-2009 05:13 PM
edge comp or edge juice w/attidue fitz1985 5.9L Cummins (1998.5-2002) 13 10-03-2007 01:43 AM
Edge Drag Comp vs. Edge Juice/Attitude lbdodge24v 5.9L Cummins (1998.5-2002) 12 03-08-2007 08:31 PM
edge juice and edge comp??? masonjo 24 Valve Performance 19 01-23-2007 11:51 PM
stacked my edge comp with my drag comp today, it hauls butt OFFRODEN 5.9L Cummins (1998.5-2002) 22 11-30-2006 06:43 PM
