Required Voltage to LP ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by scott 1, this thread has received 1 replies and been viewed 968 times.
post #1 of 2 (permalink) Old 09-15-2010, 08:26 PM Thread Starter
Hi!
Does anyone know the correct voltage from the ECM to the LP. Right now I have a hard start, And I know I have an air problem (parked on a downhill slope and she busted right off Got that great info from another member) but i 'm only at 8 volts. Turn the key and LP excites but doesnt pump fuel untill its running. (14 PSI when running) If I replace pump which pump would you run Raptor or BD?
Thanks In Advance for any help!
scott 1 is offline
post #2 of 2 (permalink) Old 09-25-2010, 03:34 AM
TDG Mafia
Jeffybuilt's Avatar
Raptor/Air Dog/or Fass is your best bet. Go with any of these and you should be A-OK
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
Service required on overhead fjwill 6.7L Cummins (2007.5-2011) 6 04-06-2010 09:57 PM
Diesel Additives required? BCMC 6.7L Cummins (2007.5-2011) 10 01-25-2008 04:04 AM
The required first post jserfas Introductions 4 12-19-2007 09:10 PM
Thought Required King of Obsolete Medium and Heavy Duty 10 09-23-2007 03:07 PM
Time Required?? Extended Power 2003-2007 6.0L Power Stroke 3 12-10-2006 07:40 PM
