LP question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JUMPSTER93, this thread has received 3 replies and been viewed 885 times.
post #1 of 4 (permalink) Old 09-28-2010, 01:29 AM Thread Starter
LP question
I just replaced the factory pump with a FASS system in my 2000 24 valve. When the truck is cold, it will fire right up. But when I drive it and get the motor hot, it will give me a long crank time on restart. I have a fuel pressure light on the truck, and it never comes on. I have only seen it light up once, and it is set to light up at less than 7 psi. Any thoughts???
JUMPSTER93 is offline
post #2 of 4 (permalink) Old 09-28-2010, 02:10 AM
TDG Mafia Goon
BombDocDiesel's Avatar
Did the original lift pump fail? Sounds like it may have done damage to the VP44.
Also I would put a fuel pressure gauge on there and not rely on the "it's too late" light. I was lucky and caught my lift pump on start up with under 5 PSI and she sat until my Airdog went in.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #3 of 4 (permalink) Old 10-12-2010, 10:53 PM
i had similar problem i put second pump in tank and cranked for ever before starting had to put toggle switch in for pump it was giving to much pressure and wouldnt start
redneckroughneck is offline
post #4 of 4 (permalink) Old 10-14-2010, 05:16 AM
you need to know what your fuel pressure is and if your lift pump failed then you may of killed your vp too. try bumping the key to get fuel pressure up wait till lift pump turns off then start it.
01quadcab is offline
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 03:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 12:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 12:40 PM
