Rear Brakes Grabbing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by joeycam, this thread has received 4 replies and been viewed 2358 times.
post #1 of 5 (permalink) Old 10-20-2010, 08:58 PM Thread Starter
GotRamCumm'
Question Rear Brakes Grabbing
Recently we have been having problems with the rear brakes grabbing. We have pulled the wheels/drums and the brakes are like new. We can't find any reason for the brakes to be all of a sudden acting up. Has anyone experienced this?
2001 Dodge RAM 2500 CTD 5.9 24v, FASS, DrawStraw + CTD 8.3 in 40' CountryCoach RV
joeycam is offline
post #2 of 5 (permalink) Old 10-21-2010, 04:26 PM
Singles Club #2
smokndiesel7588's Avatar
have you checked that the master cylinder is still good?
Greg
smokndiesel7588 is offline
post #3 of 5 (permalink) Old 10-24-2010, 01:03 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Have you backed off the parking brake cable adjustment just a hair?
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #4 of 5 (permalink) Old 11-05-2010, 09:45 PM
Not sure why but you'll find that this is characteristic of these years drum brake trucks. Mine also does it but only on cold/wet days. But I've had GM and Ford drum brake trucks that have never done it. And its only the first stab of the brakes too. The rest of the day they're fine. Its always good to check for leaking cylinders, broken springs, maladjustments, worn parts, etc, but as you noticed, its common to find nothing wrong. Almost like its brake dust build up or the way the OEM shoes react to the thin layer of rust that builds up overnight on those cold/wet days.
'01 Dodge Ram 2500 4x4 5spd Sport, EZ, Straight piped, aFe intake, Rancho 9000x's, 285's, Pac Brake, 2 lo kit, Dakota FP and Isspro boost/EGT gauges on the pillar, Raptor with 1/2" big line kit.
KATOOM is offline
The Following User Says Thank You to KATOOM For this addition to TDG:
97CumminsTurboDiesel (11-05-2010)
post #5 of 5 (permalink) Old 11-06-2010, 12:56 PM
bmoeller's Avatar
ANY dampness on the shoes that is oil from the axle? Takes almost nothing, and they get grabby. Worse when the weather is damp.
My '97 did that, but all I did was lightly sand the shoes and it never did it again the whole time I owned the truck (9 yrs). Never even replaced the seals. Never leaked enough to bother with them.
"Obama = Hoax and Chains"
bmoeller is offline
Tags
grabbing brakes, rear brakes
Rear Brakes POWER STROKE 99 1994-2003 7.3L Power Stroke 3 03-08-2010 10:43 AM
Rear Brakes go200mph 2008-2010 6.4L Power Stroke 4 02-03-2010 02:36 PM
Brakes grabbing rjrspecialops 2008-2010 6.4L Power Stroke 11 12-28-2009 08:36 PM
More brakes in rear? Horsehaulin Medium and Heavy Duty 4 02-20-2007 02:15 AM
Rear Brakes PSDan000 1994-2003 7.3L Power Stroke 9 07-08-2005 12:56 PM
