truck luging - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by heathww, this thread has received 4 replies and been viewed 940 times.
post #1 of 5 (permalink) Old 10-23-2010, 02:37 AM Thread Starter
truck luging
hey guys all of you have helped me in the past and now need help again my truck starts and idles but when i put it gear and give it some throtle it just jerks like its not getting fuel my fuel pressure guage says i have 16lbs so i know i got fuel i am thinking it might be my tps my truck 01 pyro,boost,fuel guages pac brake with bd torque lock
heathww is offline
post #2 of 5 (permalink) Old 10-23-2010, 02:53 AM Thread Starter
i forgot to mention i also have edge comp
heathww is offline
post #3 of 5 (permalink) Old 10-23-2010, 03:05 AM
Have you checked for codes?
later is offline
post #4 of 5 (permalink) Old 10-24-2010, 01:05 AM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
Also unplug your comp box and try that.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #5 of 5 (permalink) Old 10-24-2010, 10:43 PM
TDG Mafia
Jeffybuilt's Avatar
Mine did the same thing, and after checking and cleaning all connections, disconnecting the Comp box, etc, I found it was a MAP sensor. Once I replaced that, my problem was solved.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
Good donor truck for race truck Superdutytd General Ford Truck and Excursion 0 10-07-2009 09:43 PM
stock truck quite/tuned truck loud? rstaichi 2008-2010 6.4L Engine Tuner Forum 16 04-16-2008 02:02 AM
my truck and a buddies truck at ocotillo pics dieselboy740 4X4 Offroad Forum 16 11-19-2007 10:53 PM
had my truck at the local truck pull to night SmokingIDI_7.3L 7.3L and 6.9 IDI (Pre 1994) 3 06-17-2007 06:24 AM
NASCAR Truck Series - Powerstroke truck sredish General Ford Truck and Excursion 14 07-01-2006 12:25 PM
