found codes need help - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by heathww, this thread has received 2 replies and been viewed 692 times.
post #1 of 3 (permalink) Old 10-23-2010, 07:11 PM Thread Starter
i bought a code reader today and they are 0237,1688 but when i clear the codes 1688 stays gone but 0237 comes back i beleive 0237 is map sensor but need help to confirm that and how fix or replace
heathww is offline
post #2 of 3 (permalink) Old 10-23-2010, 10:42 PM
Sorry to hear you bought a code reader, you can turn the key on and off 3 times and stop on the third and the speedo will tell you what codes you have. You can clear all codes by disconnecting both batterys for 2 hours. Check out mopar1973man web site I am sure he has a good write up on how to clean a MAP sensor with carb or brake cleaner. Good luck.
later is offline
post #3 of 3 (permalink) Old 10-24-2010, 04:02 AM Thread Starter
no disrespect but i know about the three key thing but it only tells you the companion codes and not the seperate codes that come with the companion codes the only code that came up when i did the three key test is 1693 no details
heathww is offline
Look what I found . BROKER 2011+ 6.7L Power Stroke Diesel 23 04-08-2010 11:48 AM
found were my oil is going Stroker99 1994-2003 7.3L Power Stroke 6 02-09-2010 12:29 PM
Just found you Mike_B Introductions 7 04-06-2007 12:59 PM
Found a old pic of the 97 CSIPSD 1994-2003 7.3L Power Stroke 7 03-21-2006 06:26 AM
Found me a J/D. What do you think? Duke Utility & Farm Tractors 7 06-08-2005 08:51 PM
