hot rod vp44 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by customdeluxe78, this thread has received 6 replies and been viewed 3100 times.
post #1 of 7 (permalink) Old 10-24-2010, 03:03 PM Thread Starter
99 cummins
customdeluxe78's Avatar
hot rod vp44
Would like to hear some feedback on the hot rod vp44. Anybody using one? My pump is still working but power hasn't been consistant. Sometimes the truck feels like an indy car and other times its kinda weak. My pump has been starved twice that i know of in the past and it has over 190,000 miles on it. I'm thinking about the upgrade even before my pump goes completely bad. What do you guys think?
99 cummins, 5-speed, edge comp, speedhut guages, fass 150 system, s&b cold air intake, ces two piece manifold, 5 inch straight exhaust with a 6 inch tip, 5 inch superlift, 4:10 gears, dynatrack lock in lock outs, 35x14.50 thornbirds on 16.5x12 mickey tompson classic 2's, alpine head unit, 1600 watt amp, 2 12 inch subs
customdeluxe78 is offline
post #2 of 7 (permalink) Old 10-24-2010, 04:46 PM
Let it rip tator chip!
97CumminsTurboDiesel's Avatar
I like mine! Gained alittle more fuel milage, noticed a power difference between the stock and the hotrod. The bad thing about it is, if you do alot of short driving it kills it quick! but other then that, it pretty good.
Riding Dirty #60
B.O.M.B Squad #79
Singles Club #260
Special thanks too
xtremediesel.com
dieselperformance.com
cptrucks.com
post #3 of 7 (permalink) Old 10-24-2010, 07:54 PM Thread Starter
99 cummins
ok thanks, i usually run the engine for a while after i start it, very few short trips. but thats good to hear that i'll gain mileage too!
post #4 of 7 (permalink) Old 10-25-2010, 04:18 PM
have done testing with my truck and the hrvp doesn't gain you any more power. It costs more and can cause weird idles and they cost more. The mileage gain talked about could be related to an old pump going bad. I know I went from a 185k mile pump to a 85k miles pump and hp was more consistent.
01quadcab is offline
post #5 of 7 (permalink) Old 10-25-2010, 08:03 PM
Official TDG Doctor
hccumminssmoke's Avatar
waste of $$$ stick with a SO pump they'll make all the power you need, if not buy a monster...
Nate
hccumminssmoke is offline
post #6 of 7 (permalink) Old 10-29-2010, 03:11 PM
I run a scheid lightening pump on my truck, and I am very happy with it. I haven't done any back to back testing with it, so I do not know how it compares to the SO pump, but it does fuel a lot harder down low than the SO pump, that is for sure. The circumstances under which I got mine made it worth it for me to go that route. Normally, I would just say go with an SO pump.
post #7 of 7 (permalink) Old 11-05-2010, 09:31 PM
Reliability is the issue for me. I understand that the SO pump is more reliable than the Hot Rod VP. The way I looked at it when I changed out my VP was that the Hot Rod was more expensive but doesn't last as long, so why would I want to spend the extra money on something that only yields minimal HP gains but cost A LOT to replace? I'd rather take that money and invest it in a box or injectors and get far more power for the dollar.....and have the VP be as reliable as possible.
'01 Dodge Ram 2500 4x4 5spd Sport, EZ, Straight piped, aFe intake, Rancho 9000x's, 285's, Pac Brake, 2 lo kit, Dakota FP and Isspro boost/EGT gauges on the pillar, Raptor with 1/2" big line kit.
KATOOM is offline
Hot VP44 or Blue Chip's VP44 Mad Dog Cycles 24 Valve Performance 12 05-03-2009 01:38 AM
VP44 Please JLWelding Supporting Vendors Forum 4 04-07-2009 10:16 PM
Vp44 JLWelding 24 Valve Performance 14 04-05-2009 05:49 PM
Vp44 jackal50302 24 Valve Performance 4 11-27-2007 02:49 AM
vp44 Jamison Whats Been Sold 0 11-07-2007 11:42 PM
