2001 cummins rod knock?? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 4 replies and been viewed 6880 times.
post #1 of 5 (permalink) Old 11-16-2010, 03:11 AM Thread Starter
IDImonsterstack's Avatar
ok guys i got a serious problem here a few weeks ago when i was driving around on the free way doing 70 very light throtle my egts would sky rocket to like 1400-1500 and then go back to normal it did this a few times then one day drining 55 cruising the motor started making a super loud knock like a rod the truck is running on 5 cylinders and knocking like mad. i have perfect oil presure and oil looks good do you think one of the injectors broke??? if so should i pull the head off just to make sure nothing is messed up?
under the knife for rebuild
IDImonsterstack is offline
post #2 of 5 (permalink) Old 11-16-2010, 06:00 PM
bmoeller's Avatar
Did you just install that PS66 turbo by chance? If no plans to add more fuel, that is more turbo than you really need for just a Edge Juice and 100hp sticks. A 64/14 would've been plenty.
Otherwise, I'd say you have a dirty air filter, boost leak or severely retarded timing. Any excess black or white smoke?
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 5 (permalink) Old 11-16-2010, 08:43 PM Thread Starter
no the smoke is normal a little white smoke id say and some blue but no excess in black smoke. the turbo works great the egts never hit over 1250 then all of a sudden this happened im wondering if the KDP fell out
post #4 of 5 (permalink) Old 11-20-2010, 09:23 PM
bmoeller's Avatar
KDP doesn't sound that likely to be causing this problem. And, IIRC, th '01 trucks should have the updated case with the stepped hole. Shouldn't be a problem anyhow.
bmoeller is offline
post #5 of 5 (permalink) Old 11-20-2010, 11:59 PM Thread Starter
yeah i figured it wouldnt be the KDP but my oil presure is fine i am wondering if one or more of my injectors has fialed causing an injector knock?? casue the truck does have a dead cylinder at least one that i know of. if i take the injectors out and crank her over and it does no knock at all with that tell me anything?ive checked the oil and i dont se any metal maybe a flake or two bu maybe normal maybe not.
2001 s10 want a cummins 6.5t seakone30 Diesel Conversion 4 06-07-2010 10:47 PM
turbo on 2001 5.9 Cummins IDImonsterstack 5.9L Cummins (1998.5-2002) 12 05-05-2009 08:48 PM
2001 cummins 7.3ford350 5.9L Cummins (1998.5-2002) 2 09-09-2007 03:35 AM
2001 Cummins q/c s/b 4x4 800hp?? dieseldjms Whats Been Sold 13 08-23-2007 11:54 AM
