Blown Head Gasket - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JLWelding, this thread has received 4 replies and been viewed 1267 times.
post #1 of 5 (permalink) Old 11-23-2010, 03:27 AM Thread Starter
JLWelding's Avatar
Blown Head Gasket
I put a rebuilt head on my truck and it blew gasket in about 3 days now it has a slite miss , I am guessing between cylinders, have not ran compression test yet.
I need some sugestions on what I need to do next time. I torqued the head 50 the first round, 77 the second and rechecked the third round then 1/4 turn after that.
Shoud I try copper coat on gasket? Torque a little more? Get new bolts? I heard 3rd gen bolts a little stronger?
JLWelding is offline
post #2 of 5 (permalink) Old 11-23-2010, 06:26 PM
Have the head checked for flatness. Is where I would start. New stock bolts also go a long ways, and can be taken all the way up to 150-155ft.lbs if done right.
post #3 of 5 (permalink) Old 11-23-2010, 10:46 PM
ADMIN/MAFIA
neeltburn's Avatar
Check head for flatness is the best thing you can do. Then I would atleast get new bolts of look at APR 425 head studs and do it right the last time. Also make sure you get the block good and clean before it goes back together.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #4 of 5 (permalink) Old 12-22-2010, 07:09 AM
The head is coming off again?
At least O ring and stud the thing after checking the head and deck for flatness. Torquing up to 130 lb/ft sound good?
I did mine right the first time I blew my head gasket because I didn't want to do it again soon....
TwinCharger is offline
post #5 of 5 (permalink) Old 12-28-2010, 01:30 AM
I wouldn't worry too much about o-rings. Especially not at his power level. With a good flat head, and bolts or studs done right, you are good for a fair amount of power. If you are pushing some big numbers, then I would start looking into ARP625's. We run 1200hp through our 05, without o-rings, and I have also heard of people loosing HG's because of their rings, so I am not a fan of complicating matters, or spending more coin than necessary.
Help Is My Head Gasket Blown ukrainianmudking 2008-2010 6.4L Engine Tuner Forum 20 03-14-2010 08:14 PM
blown head gasket jlund 2003-2007 6.0L Power Stroke 11 08-05-2009 01:09 PM
Blown Head Gasket Dieselson Duramax 2001-2004 (LB7) 13 08-15-2007 11:00 AM
Blown Head Gasket? Klutch 1994-2003 7.3L Power Stroke 16 07-04-2007 09:30 PM
Blown Head Gasket xxxotiknightz 5.9L Cummins (1998.5-2002) 12 05-03-2007 01:33 AM
