01 valve springs - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 7 replies and been viewed 1375 times.
post #1 of 8 (permalink) Old 11-24-2010, 05:23 AM Thread Starter
IDImonsterstack's Avatar
01 valve springs
ive got a couple broke valve springs was wondering if i can change them in the truck or should i pull the head and do them? since ive got 2 that are broke im gonna replace all of them and be smart and the push rods at the same time.
under the knife for rebuild
IDImonsterstack is offline
post #2 of 8 (permalink) Old 12-22-2010, 06:50 AM
I would pull the head. Why do something twice? You are facing enough headaches. Did you deck the block and check the head for warpage?
TwinCharger is offline
post #3 of 8 (permalink) Old 12-22-2010, 10:16 PM
They make a tool for changing them on the truck, BUT you need to be sure the piston in the cylinder you are working on is at top dead center.
later is offline
post #4 of 8 (permalink) Old 12-23-2010, 08:49 AM Thread Starter
yeah i know that. well changing the springs arnt even an issue right now since right after i posted that i found that instead of a broken spring the valve broke off an the motor ate it so im in the process of ripping the motor out and rebuilding it
post #5 of 8 (permalink) Old 12-23-2010, 02:59 PM
Do you need any parts?
later is offline
post #6 of 8 (permalink) Old 12-24-2010, 06:37 AM Thread Starter
i still got to get the motor out but more then likley a good head or rebuilt on with valves and springs. got to see how bad number 5 cylinder is if its gonna have to be sleeved or not. what parts do you have?
post #7 of 8 (permalink) Old 12-24-2010, 01:00 PM
I have a short block setting on the bench, but it should be bored out. You could run it very loose but I would just go ahead and spend the extra 500 and get it bored .040 and blueprint and blance.
later is offline
post #8 of 8 (permalink) Old 12-26-2010, 04:21 PM Thread Starter
does it just have a lot of miles on it? how much would you want for it?
valve springs the blue beast 2003-2007 6.0L Power Stroke 14 02-03-2010 02:12 PM
60 lb valve springs.... Broncboy 5.9L Cummins 12 Valve (1994-1998.5) 3 04-23-2008 09:57 PM
valve springs Dual K20s 5.9L Cummins 12 Valve (1994-1998.5) 1 05-13-2007 04:14 AM
cummins 60 lbs valve springs 12 valve imported_machine2 Whats Been Sold 0 05-07-2007 11:58 PM
Valve springs jktcummins 24 Valve Performance 3 04-29-2007 04:08 AM
