2001 vp44 to common rail - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 9 replies and been viewed 2018 times.
post #1 of 10 (permalink) Old 11-29-2010, 06:03 AM Thread Starter
IDImonsterstack's Avatar
my truck ate the number 5 intake valve and number 6 intake valve it destroyed the moter it cracked the head and broke the pistons and ate the cylinders i was wondering if i could put the newer common rail in my truck since i have access to one really cheap. as far as i know i can use the exhaust manifold and turbo off mine but i was wondering about the electrical and stuff?
under the knife for rebuild
IDImonsterstack is offline
post #2 of 10 (permalink) Old 11-30-2010, 01:27 AM
JLWelding's Avatar
I was going to try the same thing, everyone I talked to says sensors wont work with our ecm's. And the 03 and newer wont work with pcm.
JLWelding is offline
post #3 of 10 (permalink) Old 12-01-2010, 12:15 AM Thread Starter
yeah thats what i was worried about my self i wonder if there is a way to adapt the wires to the newer harness? ither that or im just gonna build up the another motor to put in
post #4 of 10 (permalink) Old 12-02-2010, 03:31 AM
ADMIN/MAFIA
neeltburn's Avatar
It wouldn't be any different than doing a PSD to Cummins conversion. But it would be easier to just fix the 24v or put in a replacement 24v from a donor. Could it be done, Yes. would it be cost effective? prolly not.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #5 of 10 (permalink) Old 12-02-2010, 05:50 AM Thread Starter
yeah i started looking around and i think just rebuilding mine and doing a hi-performance rebuild is about the same as a stock CR implant. one thing i was wondering can i use the 17.2:1 pistons from the HO 2001 cummins in the SO motor with the SO pump and computer? i have 100hp injectors was thinkin it would be a little bit of an upgrade. im gonna do a cam and head studs fire ring the head the whole thing.
post #6 of 10 (permalink) Old 12-04-2010, 06:02 AM
The lower compression is a better way to go if you are going to do any kind of performance upgrade. If you do do the CR swap, you will need a CR ECM. I have a complete set up, that I was thinking of throwing in mine, including AAM axles with the larger ring gears and disc brakes as well. Its kind of a ***** with smog out here, and having to go to a ref. even to drop in a newer engine, but... It would be pretty cool. I've got a line on a whole truck minus the trans and transfercase if you're interested, I doubt I will get around to it soon, and can always find another one.
post #7 of 10 (permalink) Old 12-04-2010, 09:33 AM Thread Starter
ok the one thing i was wondering is will my 2001 wiring harness on my ECM plug into the common rail ECM? thats my main concern casue i can get a loaded common rial with the computer drop in ready to go for 3000 its the 2004.5 CR i was gonna put my 2end gen manifold and HX 40 on it so i can reuse my intercooler pipes and everything
post #8 of 10 (permalink) Old 12-06-2010, 03:36 AM
I was wondering how you can have all that damage to the motor and figure the turbo is OK. I would really check the turbine for damage.
Johnp3 is offline
post #9 of 10 (permalink) Old 12-07-2010, 06:38 PM Thread Starter
i have pulled the turbo off a week ago i pulled in apart i do have tip of the exhaust wheel bent i got another wheel and had the shaft checked and its fine. i got a rebuild kit from industrial injection for the PS 66 i rebuilt it and tested it on my buddys truck and works good.
post #10 of 10 (permalink) Old 12-08-2010, 03:16 AM
I have a 12v sitting in my garage at home that lost the #6 valve and did some huge damage. Looked like world war III in there. But the turbo that was on it is fine. Not that that always happens, but definitely isn't unheard of.
keep the 12v or go common rail???? JPscustoms Cummins in Fords 13 06-20-2010 04:43 PM
2005 Common Rail southern-stroke 5.9L Cummins (2003-2007.5) 11 01-30-2010 06:13 AM
new to common rail dangerous196 5.9L Cummins (2003-2007.5) 14 02-20-2008 07:30 AM
common rail? uh oh, 6.0 2003-2007 6.0L Power Stroke 13 11-28-2007 11:28 PM
VP44 to common rail sklo 5.9L Cummins (1998.5-2002) 6 03-31-2007 07:26 PM
