Fuel Pressure. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by southern-stroke, this thread has received 9 replies and been viewed 1292 times.
post #1 of 10 (permalink) Old 12-19-2010, 10:08 PM Thread Starter
southern-stroke
southern-stroke's Avatar
Send a message via MSN to southern-stroke
Fuel Pressure.
I was drivin a buddies 99 24 valve over the week and noticed his fuel pressre gauge on both his pillar and edge cts was showing about 30 psi at idle. Does this sound right?
''Can You Keep Up?'' while I'm ''In The Passing Lane!''
southern-stroke is offline
post #2 of 10 (permalink) Old 12-19-2010, 11:26 PM
ADMIN/MAFIA
neeltburn's Avatar
ShoUld be about 15psi at idle and not under 10-12 at WOT.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 10 (permalink) Old 12-20-2010, 12:48 AM Thread Starter
southern-stroke
Is it bad or good that it's so much more?
post #4 of 10 (permalink) Old 12-20-2010, 02:18 AM
Official TDG Doctor
hccumminssmoke's Avatar
30 could be a bit high, i run 25...to little your pump will starve and crack the diaphram, too much and the pressure CAN crack the diaphram, i know quite a few people that run 30+, but thats on pulling trucks that are calling for A LOT of fuel....
Nate
hccumminssmoke is offline
post #5 of 10 (permalink) Old 12-20-2010, 02:45 AM
TDG Mafia Goon
BombDocDiesel's Avatar
What pump is he running? I would turn it down a bit if it were mine.
-Josh-
My Gassers
TDG MAFIA!! MAFIA Application
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
BombDocDiesel is offline
post #6 of 10 (permalink) Old 12-20-2010, 02:52 AM Thread Starter
southern-stroke
He's running a stock SO pump. No aftermarket lift pump or injection pump. Actually, it's stock everything except for stacks gauges and a K&N filter on the end. He has the juice and CTS installed but can't run it on anything other than stock cause his tranny slips.
post #7 of 10 (permalink) Old 12-20-2010, 03:03 AM
TDG Mafia Goon
He has a stock pump hitting 30? It's about to die. My stock pump ran 15 tops and barely hit 10 at WOT. That was with a 10PSI pump in the tank feeding it (long story).
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
post #8 of 10 (permalink) Old 12-20-2010, 09:31 PM Thread Starter
southern-stroke
Yeah, it's all stock. I asked him about it and he said that it's supposed to be about 30 psi at idle and 25 psi at WOT. That's when I remember readin somethin on here about 12 at idle and 10 at WOT.
post #9 of 10 (permalink) Old 12-30-2010, 07:59 PM Thread Starter
southern-stroke
So how much would it cost to replace the pump? And how big of a pain is it to replace it?
post #10 of 10 (permalink) Old 12-30-2010, 09:19 PM
TDG Mafia Goon
Put an AirDog or FASS in there and be done with it. I recommend the AirDog because it's much more quiet than the FASS in my experience. You can then remove all the factory fuel housing crap and tie up the WIF and heater circuit. Go to any of the auto stores and buy a SBC fuel pump block, remove the factory bracket on the block and install the SBC block. It looks so much better.
I run my fuel pressure gauge from AirDog housing but you can still run from the banjo if you really want to.
AirDogs run $400-$500+ and it takes an hour or two depending how you do it. I pulled the bed on mine.
-Josh-
My Gassers
American Club #38
B.O.M.B. Squad #55
Singles Club #248
Army Bomb Squad!
fuel pressure question? fuel filter or over flow valve? hereismylife 5.9L Cummins 12 Valve (1994-1998.5) 23 04-09-2010 12:33 AM
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 06:33 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-09-2009 11:35 PM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 02:25 PM
Fuel Mods: X-over vs full fuel kit and pressure... bakantor 2003-2007 6.0L Power Stroke 39 03-10-2007 02:06 PM
