p-pump conversion - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dodgedisorder, this thread has received 26 replies and been viewed 6055 times.
post #1 of 27 (permalink) Old 12-22-2010, 06:38 PM Thread Starter
ricer's suck!
p-pump conversion
hey guys im about to convert my truck and was wondering if anyone has done this and could help me out with any suggestions or tips to make it as smooth as possible.
id really like to know the best way to get the cam gear off and back on without hurting anything and the best way to time the pump in.
any help would be great thanks guys
2000 Dodge Ram CTD 2500, P-Pumped 180hp, ddp 150's, s300, nice camshaft, fass 150, CAT filters, full 6speed conversion all the way to the dana 80 w/ disc brakes, zoom ceramic clutch
388hp/ 959ftlbs
soon to come;
progressive nitrous, latter bars
dodgedisorder is offline
post #2 of 27 (permalink) Old 12-22-2010, 10:09 PM
Well in my case I had the cam out and took it to a machine shop and got them to press it off. To put it back on you need to bake it in the oven at 375 for 30 -45 min. then install it on the cam. It helps if you have the cam in the Refrigerator over night and I perfer the frezer. You will want to have a couple of blocks of wood on hand and a 2 or 3 pound dead blow hammer.
later is offline
post #3 of 27 (permalink) Old 12-23-2010, 11:45 PM
I put mine in the freezer too! The girlfriend was all like, "Uhh, whats for dinner??"
Then she found the gear in the oven. Priceless!
Are you getting the mild steel lines? I heard big lines on VP injectors will give you a weird idle. The stock size lines on a VP injector will idle a lot better, but I do not know first hand. This is something I read on another board.
TwinCharger is offline
post #4 of 27 (permalink) Old 12-24-2010, 12:56 AM
I have .75 lines.
The truck is a daily driver that is not finished the pump is out to the shop and will not be back until after the first of the year. If I was going to a 13mm pump I would want bigger lines they have .093 .120 and .187 that I know of and I wanted mild steel just because I was told they are having problems with the stainless cracking. I do not know if that is true or not but I will paint mine to make it look more like a 12V to the unknowing.
We are old enough that when I do something like putting the cam in the freezer she will just ask what I am up to and how much is this costing?
later is offline
post #5 of 27 (permalink) Old 12-24-2010, 08:59 AM Thread Starter
ricer's suck!
im going to try out the ss .093 lines, its gona idle rough and be rough at low rpm for a street truck but its gona a fun truck once its complete
388hp/ 959ftlbs
soon to come;
post #6 of 27 (permalink) Old 12-24-2010, 12:55 PM
What all are you doing to the pump?
later is offline
post #7 of 27 (permalink) Old 12-24-2010, 06:32 PM Thread Starter
ricer's suck!
i have 4k springs in it with a ground plate, but i havnt figured out what i wanted for DVs yet, i want it to have some what of street maners, what are most guys runnin that drive them daily?
388hp/ 959ftlbs
soon to come;
post #8 of 27 (permalink) Old 12-24-2010, 07:44 PM
I am starting out with 131's DV's and 8X12 injectors.
later is offline
post #9 of 27 (permalink) Old 12-24-2010, 08:25 PM Thread Starter
ricer's suck!
im going to start with stock DVs with 150hp ddp inj. and see how hot she gets then ill experiment
388hp/ 959ftlbs
soon to come;
post #10 of 27 (permalink) Old 12-28-2010, 01:26 AM
What are you guys running your timing at? Also, there is a fitting for the oil feed that you are supposed to run to keep from over supplying the pump resulting in too much pressure inside the pump and improper operation. That is the only issue that we ran into on my friend's truck.
For the cam gear, I personally pressed mine off when I did mine, but the cam I installed switched over to a bolt on style cam gear instead of press on.
P-pump conversion ironhead107 5.9L Cummins (1998.5-2002) 6 08-30-2009 03:14 PM
24V P Pump conversion ash_flat_diesel 24 Valve Performance 15 03-25-2008 10:24 PM
p-pump conversion jd_craft 5.9L Cummins (2003-2007.5) 10 03-20-2008 01:46 AM
P Pump Conversion? hemichallenger 5.9L Cummins (1998.5-2002) 2 09-25-2007 03:17 PM
Bosch P pump conversion j41385 5.9L Cummins (Pre 1994) 4 01-26-2006 06:20 PM
