Looking for sixth gear - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Wittsman, this thread has received 15 replies and been viewed 1856 times.
post #1 of 16 (permalink) Old 02-07-2011, 01:36 PM Thread Starter
Hey guys just looking for some advice on either a tranny swap or a gear vendors overdrive addition which one would be easier/cost/better mileage/durability I have a nv4500 now was thinking a nv5600 swap or a gear vendors any info would be great!!
Wittsman is offline
post #2 of 16 (permalink) Old 02-08-2011, 02:45 AM
bmoeller's Avatar
Cost per mile really high on the GV.
The 4500 and 5600 trannys have the same (or close) O/D ratio, so no gains there.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 16 (permalink) Old 02-08-2011, 05:50 AM
little taller tire, upgrade to synthetics in diffs. will help gain a little mpg's. or a set of rv275 injectors. Just taking a stab here in guessing what your looking for
01quadcab is offline
post #4 of 16 (permalink) Old 02-08-2011, 07:09 AM
hayjayhorses's Avatar
the 6sd has closer ratios in the gear set OD is about the same, If you are hauling in the hills (I do) the 6 speed (NV5600) will make a big differnce.
If you are looking for fuel mileage run higher gears. I have a 98 12 valve with a 5 speed and 3.55 2wd it will gear 22-24 mpg when it try. That means traveling 60-65 with no trailer, run 75mph and it gets like 17-18mpg.
they do make 3.42 and 3.21 gear set also.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
post #5 of 16 (permalink) Old 02-08-2011, 07:29 PM Thread Starter
Yes I'm looking for a little more mileage I have a 98 3500 4x4 drw24v nv 4500 3.55 gears 4"turbo back straight pipe air dog150 leveling kit and 35" inch rubber not sure if I should put money in a overdrive or a freespin hub kit!
Wittsman is offline
post #6 of 16 (permalink) Old 02-09-2011, 12:04 AM
bmoeller's Avatar
What kind of mileage do you get right now? What size tires are you running? been thinking about some 33 or 35" rubber on my '99. Have 4.10s in mine and get low 16s on a long trip. 12's loaded up and rolling.
bmoeller is offline
post #7 of 16 (permalink) Old 02-09-2011, 12:49 AM Thread Starter
I haven't calculated what mileage I get right now. I have 35x12.5 on stock wheels. Next is a programer looking at banks or a smarty jr what do you think is the best bang for the buck in a economy tune??
Wittsman is offline
post #8 of 16 (permalink) Old 02-10-2011, 12:51 AM
no banks. would say get and edge ez if your looking for low hp gains, or a edge comp and some gauges. well most important question is what lift pump is on this truck.
post #9 of 16 (permalink) Old 02-10-2011, 01:32 AM Thread Starter
I put a Air Dog 150gph with a Hellman sump pickup!
Wittsman is offline
post #10 of 16 (permalink) Old 02-10-2011, 03:01 AM
that freespin kit gave my buddy almost a 2 mpg jump don't remember how much it cost not sure on the older 24valve trucks but wouldn't a smarty on them be a little better than edge in the mileage department i don't know not that experienced with the older 24 valves just 12's and common rails
04 Dodge 4x4 crew cab 6sp valair kevlar/ceramic clutch stage 1 industrial injectors superphat shaft 62 turbo hot juice with attitude ats arc flow 5in exhaust isspro ev2 gauges and 150 airdog soon to come studs intercooler not sure after that
01 ex cab powerstroke 4x4 diablo programmer autometer gauges str8t pipe and i think the oil pump is dead b/c it wont start and im getting fuel
silverpeteok is offline
The Following User Says Thank You to silverpeteok For this addition to TDG:
Wittsman (02-10-2011)
My sixth post; bulk replies to PM's. ynot Medium and Heavy Duty 120 07-14-2009 11:15 PM
No Fitfh or Sixth Gear and No Hard Power ??? DemonicF350 2003-2007 6.0L Power Stroke 4 03-24-2008 06:11 PM
NFL Headlines Bears sign fifth- and sixth-round draft picks RSS Feeder The Parking Lot 0 06-10-2006 07:00 AM
NBA Headlines Grizzlies swingman Miller nabs Sixth Man Award RSS Feeder The Parking Lot 0 05-02-2006 07:01 AM
NHL Headlines Panthers trade '07 sixth-round pick for Flyers' Sim RSS Feeder The Parking Lot 0 01-25-2006 07:01 AM
