HARD START/ABS NOT FUNCTIONING - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99' Dually, this thread has received 2 replies and been viewed 850 times.
post #1 of 3 (permalink) Old 02-21-2011, 03:32 AM Thread Starter
been havin some starting issues with the truck in my sig. it starts great when its cold or but when its at or just a little under normal operating temp it takes a few seconds to turn over. ive only noticed it after i turned up my air-dog II to run at 30psi. and as well as this starting issue my abs lights came on during the last snow storm, i have the codes at work but pretty much said all 4 sensors show open and the speed sensor on top of rear diff has intermittant signals. ive checked wiring and connectors, all seem to be ok. hope its not the abs module itself. any info would help thanks guys.
99' Dually is offline
post #2 of 3 (permalink) Old 02-25-2011, 12:37 AM
Check your fuses. 30PSI is too hi for the VP44 injection pump. You shouldn't be pushing over 20. 30PSI is not gaining you anything. VP44 does best above 10 and below 20. The only reason we need that pressure annyways is to keep the pump lubricated, so your not gaining anymore flow than you already had. The VP will have hard starts with higher than normal fuel pressure once its warmed up. Make sure you dont have a P0216 code. If you have that it means your VP44 is on its way out.
cumminsdude2001 is offline
post #3 of 3 (permalink) Old 02-25-2011, 04:14 AM Thread Starter
the check engine light aint on and theres no codes, and i turned the fuel pressure down back to 18psi. any ideas on the ABS? still havent figured it out thanks for the help/input.
F350 hard start to no start spike 1994-2003 7.3L Power Stroke 3 12-07-2007 02:30 AM
Hard to start / white smoke at start, again. bsigg 6.5L Diesel Engine 2 11-27-2007 03:57 PM
hard start fro 2 1994-2003 7.3L Power Stroke 0 11-04-2007 08:35 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 11:55 AM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 07:32 AM
