24 valve pulling truck. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by southern-stroke, this thread has received 8 replies and been viewed 6312 times.
post #1 of 9 (permalink) Old 03-04-2011, 02:07 AM Thread Starter
southern-stroke
southern-stroke's Avatar
Send a message via MSN to southern-stroke
What all would it take to make a competive 24 valve puller. What size injectors and turbos? Head steads are a definate. Fire ringing and O Ringing? Port and Polishing? Any and all input will be apreciated.
''Can You Keep Up?'' while I'm ''In The Passing Lane!''
southern-stroke is offline
post #2 of 9 (permalink) Old 03-04-2011, 09:45 PM
ADMIN/MAFIA
neeltburn's Avatar
First thing to do is to find a pulling club in your area. You will need their rules for what class you want to run. 2.6 was an entry class but some have 2.5 (basically a work/stock class) They will have rules to has what turbo you can run, if you can run a 3.0 turbo with a inducer bushing or if it has to be a 2.6 turbo. then injectors, cam, valve springs, supporting mods, drive train saftey loops depend on club rules. you will want traction bars. Depending on how far you want to go you can p-pump it, but once again this is a big undertaking.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 9 (permalink) Old 03-07-2011, 11:06 AM
What are sparkplugs
ICEMAN3005's Avatar
Lots of money and lots of patience! If you look at my sig. there's about $10,000 and I still was far from finished. Needed to get a set of twins, fire ring the head and install a stud kit, and finish the transmission. Probably about another $5000-7000.
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #4 of 9 (permalink) Old 03-07-2011, 06:27 PM
Official TDG Doctor
hccumminssmoke's Avatar
who are you going to pull with in KY? KOTTPA? NKTPA? BOB? What class WS or 2.6?
WS you're going to need a CR Turbo for sure, sticks, electronics, a way to get it down and you're stiill not going to keep up with the CR trucks....
2.6 go with a custom charger, big sticks, P PUMP it, and go from there...
you're just not going to be able to keep up with a VP and its going to drain a lot of $$$$
Nate
hccumminssmoke is offline
post #5 of 9 (permalink) Old 03-15-2011, 11:17 PM
Cummins
kickermatt's Avatar
um its going to be really expencive. i work with 3 pulling trucks from the ttpa. it all depends on the rules about trubo size. head studing is a yes, o ring is a yes. latter bars are good. try to get a club cab long box and put duals on it. a truck like that pulls really good. if possible make a hood stack, the least exsaust resestance is reallly good. injectors can usaully be as big as you want them. drive shaft loops and trans harness are usaully required. a triple disk clutch from south bend is somthing you will want. a diffrent water cooling system is somthing you want. if you can bore you motor and make it a full roller motor that would be the best. you can push a lot more rpms. p pumping is a yes! if you can get a full billet trans that would help you be on the save side... manual or auto. it will save you from breaking. a weight box or hanging weights in the front only will help a ton. it all depends on how big you want to build your truck. value cover vents are a yes! and of cousre an awsome paint job.. adds power hahaha im kiding!
kickermatt is offline
post #6 of 9 (permalink) Old 03-19-2011, 09:12 PM
What are sparkplugs
ICEMAN3005's Avatar
Not trying too disagree with anyone but up here in Michigan a lot of the pulls are open pull or run what you brung. Only requirements are fire extinguisher, helmet, seatbelts and no riders. Don't have too me a member of a club either, and they just go by weight of truck for what class your in, add weights and you can be in a higher class. I do agree with you if your going for competition, just depends if your doing this for fun or not.
2002 dodge 2500 4x4
200 H.P. Injectors
FASS 150/150
TRUCK SOLD
post #7 of 9 (permalink) Old 03-19-2011, 09:32 PM
Cummins
kickermatt's Avatar
what? um depends on what your in. ttpa has a lot of freakin rules. all of the michigan points pulls you have to have fire suits and your trucks are regulated so much. the run what you brung class is the street class. the super street and out law classes have a tone of rules.
post #8 of 9 (permalink) Old 03-19-2011, 10:24 PM
What are sparkplugs
ICEMAN3005's Avatar
Yes I agree if your running out law, but all the pulls I have been too they weren't ttpa.
I have seen street trucks (daily drivers) pushin over 800 horses, at some of these pulls.
They weren't in fire retardant clothing, they didn't have drive shaft hoops or turbo cut offs, etc. Down in Camden MI they have pulls (diesel days) every spring any one with a diesel can try for a pull. Litchfield has also had pulls occasionally.
2002 dodge 2500 4x4
200 H.P. Injectors
FASS 150/150
TRUCK SOLD
post #9 of 9 (permalink) Old 03-20-2011, 12:49 AM
Cummins
kickermatt's Avatar
oh i see well a lot of it has to do with the club they are in. ye the fairs around hear have those pulls too but they also have a seprate day for points pulls. the ttpa it Thumb Tractor/Truck Pulling Assc. there are a lot of other clubs too i understand they might have diffrent rules.
6.4 pulling truck lubeowner 2008-2010 6.4L Power Stroke 8 07-13-2010 02:38 AM
Big Cam III in pulling truck seven Medium and Heavy Duty 10 08-21-2009 02:59 AM
pulling my truck 05dury 5.9L Cummins 12 Valve (1994-1998.5) 11 07-23-2009 03:14 AM
Build a pulling truck or pulling tractor? SOOTBANDIT The Polling Place 24 02-25-2009 04:54 PM
12 valve pulling injectors fwdcummins Whats Been Sold 1 04-13-2008 01:27 PM
