Intake elbows - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rollincoal97, this thread has received 8 replies and been viewed 2241 times.
post #1 of 9 (permalink) Old 03-06-2011, 02:17 AM Thread Starter
rollincoal97's Avatar
Intake elbows
I was wondering if anyone has ever heard of or owns a Tim's Cooler Tube for an aftermarket intake elbow? I've heard they cheaper and flow better than say a Banks High Ram, etc. Just lookin for some reviews if possible,thanks
2001 dodge cummins 24v automatic daily driver, quad cab long box, sport/slt package, AFE stage 2 intake, stock exhaust straight piped, EDGE Comp box, fass fuel pump, plugged wastegate, 33x12.5x17 PRO COMP tires and rims
rollincoal97 is offline
post #2 of 9 (permalink) Old 03-07-2011, 01:23 AM
ADMIN/MAFIA
neeltburn's Avatar
If you sig is correct, I don't see where you would see any different in an intake elbow. If you want to see a nice gain for money spent, get you a nice 4in TBE,,
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 9 (permalink) Old 03-11-2011, 02:48 AM Thread Starter
Sorry,should have mentioned i'm in the process of getting a 5" exhaust also.
post #4 of 9 (permalink) Old 03-12-2011, 03:51 AM
Intake elbows dont do a ton on vp trucks. I would find other ways to spend the money personally.
The Following User Says Thank You to sstockton For this addition to TDG:
rollincoal97 (05-13-2011)
post #5 of 9 (permalink) Old 03-13-2011, 07:20 PM Thread Starter
Im really just tryin to get better mileage and be more efficient at the moment. Would it still not be worth it, even with the 5" exhaust? I may have the opportunity to pick up a set of hardly used 100hp injectors for cheap, so a larger turbo and tranny kit will also be in the future if that happens. If this makes a difference at all.
post #6 of 9 (permalink) Old 03-13-2011, 11:46 PM
I had 0 difference in power etc between stock and an ats
01quadcab is offline
post #7 of 9 (permalink) Old 04-18-2011, 03:59 PM Thread Starter
How about egt's or mileage?
post #8 of 9 (permalink) Old 04-20-2011, 05:04 AM
I ran the same did trips to az and kansas with some results. better off with a set of small injectors like some rv275's if you want mileage stay away from too large of injector or you will be using them too much and drop mpg's.
The Following User Says Thank You to 01quadcab For this addition to TDG:
post #9 of 9 (permalink) Old 04-22-2011, 05:28 AM
um sure?
BBD Performance's Avatar
thats the truth right there if you want good mileage go with intake, exhaust, light injectors, and a mild tuner like edge EZ ect
one truck at a time www.bigbaddieselperformance.com
BBD Performance is offline
The Following User Says Thank You to BBD Performance For this addition to TDG:
Intake Elbows awhotrods 2003-2007 6.0 Tuner Forum 11 10-13-2009 12:06 AM
Performance Elbows 06 SuperDuty 2003-2007 6.0L Power Stroke 9 07-13-2009 04:48 PM
5 inch exhaust elbows StrokerDude Supporting Vendors Forum 2 03-28-2009 02:39 PM
Intake elbows? rademac 2003-2007 6.0L Power Stroke 13 11-08-2007 04:33 PM
ABout those Elbows. lee boy 2003-2007 6.0L Power Stroke 5 02-20-2007 09:47 PM
