Need advice from you 5.9 gurus.. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 69800, this thread has received 4 replies and been viewed 1076 times.
post #1 of 5 (permalink) Old 04-09-2011, 12:26 AM Thread Starter
I am a powerstroke guy. My neighbor has a 99 Cummins with 150k on it.. He was going to trade it in on a new one but I convinced him to spend 3 or 4 grand on the olde but goodie and he could keep it for another 10 years with minimal maintenence.. He has done nothing to it except recent lift pump and injector pump.. We want to replace all engine parts that are likely to go soon and bring her up to new condition. Would you guys make me a list of any componant you would replace if you wanted to go another 100K with no break downs.. Budget for engine around 3k and it has a 5 speed stick so no tranny issues. You guys know the weak points...What do you think???
Thanks in advance PS he want a chip to ...who do you like TS? etc.
Mark
69800 is offline
post #2 of 5 (permalink) Old 04-09-2011, 08:48 PM
well if he put an aftermarket lift pump fass airdog raptor or similar on it he is good. but if went with a stock lift pump change asap. if he doesn't have gauges get a edge juice with attitude it will do everything needed especially fuel pressure. 150k is nothing just adjust the valves retorque the head. add a cold air intake 4" turbo back exhaust and enjoy the truck. one issue that may arise is a cracked exhaust manifold so he may want to purchase one to have if it does happen they are not hard to change. if he is planning on a chip I would say also get a upgraded clutch like a southbend. thats all I can think of.
01quadcab is offline
post #3 of 5 (permalink) Old 04-10-2011, 02:42 PM Thread Starter
He did the upgrade lift pump and exh manifold. Retorque is a go idea. Intake and exhaust upgrade..OK but what about things like idler pulleys ...waterpump ..vacume pump..things like that
thanks
69800 is offline
post #4 of 5 (permalink) Old 04-10-2011, 08:18 PM
just run it as they can live a long time. if he is worried about them replace them, but don't see a reason to fix whats not broke. most water pumps go 200k some longer some shorter. the vac pump is fine unless it's leaking then just change the seals and it will be fine
post #5 of 5 (permalink) Old 04-14-2011, 12:42 AM Thread Starter
Well I know the powerstroke guys through all of the combined experience on the forums have come up with approximate mile for almost every componant but maybe these cummins parts just go alot longer....
69800 is offline
Cat gurus Joesixpack Medium and Heavy Duty 3 10-08-2009 03:04 PM
For the paint gurus nevrknow The Detailing, Paint & Bodyshop 3 07-21-2009 11:53 PM
Any wiring gurus out there? EB.Bldr 2003-2007 6.0L Power Stroke 13 05-01-2008 07:53 PM
Paint Gurus i need some help.... imported_Hanging_Heels 2008-2010 6.4L Power Stroke 7 02-21-2008 11:54 AM
Any computer gurus here???? danster The Parking Lot 5 05-04-2007 11:01 AM
