cummins OH kit - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by IDImonsterstack, this thread has received 16 replies and been viewed 3041 times.
post #1 of 17 (permalink) Old 04-10-2011, 11:28 PM Thread Starter
IDImonsterstack's Avatar
cummins OH kit
can any of the vendors chime in and give me a price for a COMPLETE overhaul kit price the cheapest for a 2001 cummins SO. pistons, rings, bearings, full gasket kit upper lower etc. thanks. friend is on a low budget rebuild and needs it done cheaply and fast he looking to spend in the 650-750 range for a kit nothing fancey
under the knife for rebuild
IDImonsterstack is offline
post #2 of 17 (permalink) Old 04-11-2011, 01:11 AM
Does it need new pistons?
If it does how much are you going to bore the block?
later is offline
post #3 of 17 (permalink) Old 04-11-2011, 01:35 AM
ADMIN/MAFIA
neeltburn's Avatar
click the link in my sig to the site vendors. Make your post there as it will be responded to much quicker. if you are doing pistons you will need to know what size as stated above. I am sure they will help you through all the info they will need to get you the right kit.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
IDImonsterstack (04-11-2011)
post #4 of 17 (permalink) Old 04-11-2011, 03:33 AM Thread Starter
the bore is fine still has the cross hatches but he wants to use new pistons casue they have some stress cracks in the tops from to much heat.
post #5 of 17 (permalink) Old 04-12-2011, 03:33 AM
I am sure he will be driving the same, so will he be coating the piston tops?
It may save the new pistons.
later is offline
post #6 of 17 (permalink) Old 04-13-2011, 05:29 AM Thread Starter
no his truck is all "stock" when her got it it did have watermeth, juice,propane, injectors and twins but he got it cheap becasue it had some blow by.....we tore it down and well rings were broke and we now know one piston has a crack in it. he only plans on putting an intake and exhaust.
post #7 of 17 (permalink) Old 04-14-2011, 01:32 PM
Yep,
it is easyer to do the internal stuf while the engine is on the bench, but if it will not need it why spend the time or money.
later is offline
post #8 of 17 (permalink) Old 04-17-2011, 02:48 AM Thread Starter
Originally Posted by later View Post
Yep,
the motor is out of the truck and all torn down the block has been dipped and cleaned and ready to go. i posted this in the vendors forum and have gotten nothing on it. hes looking to buy in the next week maybe a little sooner so if someone can help us get him a kit for this truck that would be great. i found kits for around 900...i got one a couple years ago for just around 750 or so but i cant remember where i got it
post #9 of 17 (permalink) Old 04-21-2011, 12:41 AM
You might post up in the vendor section again, right now it is comming up in the 99-02 dodge section.
Mean while I will check.
later is offline
post #10 of 17 (permalink) Old 04-21-2011, 10:55 AM
Check Ebay they have some for 675.
openrange is offline
new to cummins smokin6_0 6.7L Cummins (2007.5-2011) 4 10-19-2009 01:49 PM
07 cummins GotSmoke? 5.9L Cummins (2003-2007.5) 5 10-15-2009 02:09 AM
Anyone with a 6.7 Cummins on veg oil? olddaddy 6.7L Cummins (2007.5-2011) 10 02-12-2008 01:53 PM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Diesel Conversion 0 05-23-2007 05:29 AM
Cummins Conversion Adapter 460 to cummins Dieselwrencher Whats Been Sold 0 05-23-2007 05:29 AM
