What to look for when buying..... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Eloc309, this thread has received 3 replies and been viewed 2042 times.
post #1 of 4 (permalink) Old 04-15-2011, 04:27 PM Thread Starter
Hey guys I need some help on what to look for when buying a truck. I'm looking at a 2001 ext cab 4x4 auto with leather. He wants 7500 for it. 230k miles. What should I look for? How do I check for excessive blow-by? Etc? This is my first diesel and I know it's a different animal! Thanks in advance! Chris
Eloc309 is offline
post #2 of 4 (permalink) Old 04-15-2011, 10:43 PM
ADMIN/MAFIA
neeltburn's Avatar
Read the 53 Block Sticky
Have fuel pressure tested. desired pressure would be 16psi at idle. to little press 10 psi or under and you run the risk of damaging the VP44 injection pump.
Check fluids.
6.7L 68RFE 4wd
Yeah its stock.
Pac Brake Air Bags
On Board Air
Optima Redtop 34Rs
2010 John Deere 2305
9-11-2001 NEVER FORGET
neeltburn is offline
post #3 of 4 (permalink) Old 04-22-2011, 05:31 AM
um sure?
BBD Performance's Avatar
pop the intake hose off the turbo and wiggle the shaft just a LITTLE bit of play is ok check the blow buy tube and if it is just blowing like a fright train then that indicates that its worn out (not a bad thing) I have seen trucks that had so much blow buy that when it was time for an oil change all you did was change the filter because you had to add a gal a week to make up for what came out the blow by hose and they lasted for many more years and miles with all kinds of power and mods
one truck at a time www.bigbaddieselperformance.com
BBD Performance is offline
post #4 of 4 (permalink) Old 04-22-2011, 12:59 PM Thread Starter
Thanks guys! I didn't buy the truck. It was beat up too bad. Never even popped the hood. I looked at a 2000 as well. It looked super clean and he wanted 8000 for it. I was real excited. I looked all over the engine block for the 53 stamp and couldn't find it. So I figured I was safe. Well I crawled under the truck and saw that it had a massive oil leak. He acted surprised to hear that. He checked the dipstick to find he had overfilled when he changed the oil. He said that's why it was leaking. He didnt have any tools to drain some oil out so he unscrewed the oil filter and poured it into a bucket he had there. While he had the filter off I took another glance at the block only to find that 53 stamp hiding right behind where the oil filter was at. Dangit! After getting the filter back on and cranked back up it was still leaking oil. It was coming out of what you guys call the puke bottle. Now, not knowing if it was leaking because it was still overfilled or was being caused by excessive blowby coupled with the fact is was a 53 block I ran away like a little girl. lol any comments on all the oil coming from the puke bottle? After driving the truck and looking under it had a good stream coming from it. Dipstick still showing overfilled. Too much oil or blowby?
Eloc309 is offline
What to look for when buying a used 6.0L bismic 2003-2007 6.0L Power Stroke 23 05-27-2018 10:15 PM
Buying a F 350 need help Megaman 2008-2010 6.4L Power Stroke 11 06-06-2009 03:20 AM
buying a 7.3 7.3rambaler 1994-2003 7.3L Power Stroke 3 01-18-2009 10:11 PM
Buying Help FrankieC714 5.9L Cummins (2003-2007.5) 6 08-08-2007 02:29 PM
